Results 1 to 2 of 2
Reload Thread: Static Noise From Pioneer-dehp8600mp Help!!
    hadokenso's Avatar
    hadokenso is offline Junior Member
    Apr 2004
    Los Angeles, CA
    i purchased a Pioneer 8600mp a couple of weeks ago. I installed it myself and when i turn up the volume to half way there is a continuous static noise from all of the speakers. I hooked up another head unit, (Premier 840mp) and there was static noise as well. When i hooked it up to my friends car there was no static. I don't know what the problem is. Any help? Thanks.
    Rackne's Avatar
    Rackne is offline Junior Member
    Apr 2004
    Richmond, KS
    Re: Static Noise From Pioneer-dehp8600mp Help!!
    How did you wire the power and ground? Pure power has to come from the battery w/ a correct fuse no more than ten inches from the battery. Using any power source from the fuse box is undesireable. The factory ground wire should also be avoided, run your own to the fire wall, (not the dash supports, they promise ground but are false) use the same guage wire as the head unit on PWR and GRND, use a star washer on a crimped connector, screwed to a shiny sanded surface on the firewall. This is a starting place to stop the noise.
  1. Help me get rid of this engine noise before i shoot myself.
    By raga55 in forum Wiring, Electrical and Installation Help
    Last Post: 03-22-2004, 05:57 PM
  2. SERIOUS Engine noise. Im not that new to car audio...
    By conartist007 in forum Wiring, Electrical and Installation Help
    Last Post: 03-03-2004, 01:14 AM
  3. Replies: 2
    Last Post: 02-16-2004, 01:57 AM
  4. the 'famous' static noise
    By jroot in forum Wiring, Electrical and Installation Help
    Last Post: 12-29-2003, 05:49 PM
  5. head unit static on cds
    By BulldogSr04 in forum General Discussion
    Last Post: 10-19-2003, 10:42 AM
