Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Reload Thread: Amp problem? Sub problem? I DON'T KNOW!!! Help!
  1. #16
    nft987's Avatar
    nft987 is offline Junior Member
    Mar 2013
    New York, NY
    2 Post(s)
    Re: Amp problem? Sub problem? I DON'T KNOW!!! Help!
    Sorry. I am getting ALMOST no sound from the sub. What's coming through is the music. It's just very faint.
    -I have tried adjusting the gain and have tried it with the low pass filter both on and off.
    -I can hear the subwoofer from the driver's seat with the subwoofer controls on the head unit as loud as possible but what I hear then is a weak, lame sounding thump that was slightly out of phase with the rest of the music.
    -The JL Audio website has a very specific blueprint with materials and dimensions for the box they recommend for this sub so I made it myself.
    -If an additional amp is the answer, I will get one that will give it as close to 300w as possible.
    -The sub is new.
    Thanks. I really appreciate all this help.
  2. #17
    MOFOMAN's Avatar
    MOFOMAN is offline Senior VIP Member
    Jan 2013
    Michigan
    150
    44 Post(s)
    dont go an crank your gain to max it will destroy your sub you could check out amazon an look for a amp that will do 250-300 rms at 4ohms (also when you get done go have your amp gains set properly 5-10$)
    MRP-M500 - Alpine Monoblock
    Power Acoustik GT1-1000
  3. #18
    MOFOMAN's Avatar
    Jan 2013
    Michigan
    150
    44 Post(s)
    do you have your high pass filter on or stereo mode on you want your sub to be set to mono
  4. #19
    nft987's Avatar
    Mar 2013
    New York, NY
    2 Post(s)
    Thanks. I found a JL Audio mono amp on Craigslist. I'll let you know if that solves my problem. Thanks for your advice. I appreciate it.
  5. #20
    seg_representin's Avatar
    seg_representin is offline CarAudio.com Elite
    Jul 2006
    IL
    1,085
    14 Post(s)
    Quote Originally Posted by nft987 View Post
    -The sub is new.
    Music shouldn't be coming through the sub. You could possibly have the high pass filter on l ike mofoman suggested. Make sure your amplifier is set for low pass filter. Can you post the specs of your amp. I was having trouble finding that exact amplifier model when i googled it
    2012 Civic Si Sedan
    .:Real playas ride slow loud and bangin:.
  1. amp and sub problem helpp
    By loz in forum Wiring, Electrical and Installation Help
    Last Post: 11-09-2011, 05:35 PM
  2. Need immediate help. Amp or sub problem?
    By Ritter420 in forum General Discussion
    Last Post: 09-09-2008, 10:46 PM
  3. I bought my AMPS! / small Sub problem.
    By Glock23 in forum General Discussion
    Last Post: 08-20-2008, 01:30 PM
  4. need help with amp gain/subs problem
    By trunks9_us in forum Subwoofers
    Last Post: 08-09-2007, 02:32 PM
  5. Need an Amp and Sub for around $300 total please help
    By DaBurner in forum General Discussion
    Last Post: 01-16-2006, 12:58 AM
Tags for this Thread
