+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Reload Thread: single alternator vs dual alternators
  1. #16
    sexy's Avatar
    sexy is offline mind reader
    Jul 2009
    ohio
    293
    Re: single alternator vs dual alternators
    Quote Originally Posted by mensah View Post
    hello i have 1 240 amp alternator but i need more amps if i add another 240 amp alternator will that help or add 1 400 amp alternator and if i add 2 240 amp alternators make it 480 amps or a strong 240 amps
    im looking to power a dd m3b and 2 mtx 3404 amp plus 2 sets of 35 watt h.i.d lights for a 2003 aurora fully loaded i want the volts to be around 14 -15 with out a 16 volt conversion
    also i have a yellow top plus a xs power 3100
    I run 3 H/O alternators under the hood of my van. There is an enormous advantage to using mutable alternators. First off when you talk to the best builders of alternators they honestly explain that the highest output alts also produce the most heat and require the most rpms to achieve their results. Heat in an alternator accounts for about 25% loss from the rating of that alt right off the bat. Running two alts or three alts reduces the load that one alt would have seen thus reduces heat.
    Having two different batteries is costing you a bunch of power also. Batteries are another topic though but you do need to get some good info and that sure hasn’t happened. Best bet would be to do some google research.
    http://www.termpro.com/asp/competitorstats.asp?Competitor_ID=82926&SessionID= 719083735
  2. #17
    bgowdy31's Avatar
    bgowdy31 is offline IF YA SMMMEEELLLLLLL!!!!
    Apr 2011
    Campbellsville, Ky
    4,477
    61
    8 Post(s)
    Quote Originally Posted by **** View Post
    You should stop posting on electrical questions.
    whatever dude....
    YOUTUBE SEARCH- *BGOWDY31 or BGWDY3131(<-new)* FOR ME & MY WIFEYS DAILY SYSTEMS
    MY 95 CHEVY BLAZER~~~~WIFEYS 03 FORD FOCUS SE
    1 SUNDOWN ZV3 18 D2(COMING SOON)~~~1 KICKER L7 15 D4
    4.76 CUBE 1 8" AEROPORT 41HZ~~~5.6 CUBE L-PORT 42-ISH-HZ
    CRESCENDO BC3500 @ 1 OHM~~~KICKER ZX1000.1 @ 2 OHM
    DC 220A,4-0GA RUNS,2GA BIG 3,3 DEKAS 105AH EACH~~~STOCK ALT,1-8GA RUN,STOCK YELLOW TOP
    147.6-MUSIC AVG 45 SEC(PREVIOUS AMP/SUB)~~~143.8-MUSIC AVG 45 SEC
    146.8-LEGAL MUSIC AVG(PREVIOUS AMP/SUB)~~~143.1-LEGAL MUSIC AVG
  3. #18
    bgowdy31's Avatar
    Apr 2011
    Campbellsville, Ky
    4,477
    61
    8 Post(s)
    also i told him to get rid of the off yellow top and pick up a matching group 31, but i guess i thats not "good" info either. and since he said that he can get a 2nd alt for cheap i said that would work as well........ more bad info huh...
  4. #19
    robert420's Avatar
    robert420 is offline Senior VIP Member
    Dec 2012
    geneva ne
    199
    Quote Originally Posted by MutantDreams View Post
    it all depends on your level of expertise. it could be a simple rebuild if you know what your doing
  5. #20
    DDtC's Avatar
    DDtC is online now Go cheap you get cheap
    Apr 2011
    Va Beach, Va
    32
    5,926
    44 Post(s)
    Alternator>Batteries all day everyday. If you are not dropping with that BC3500 I question your volt meter
    • 2010 Scion tC
    • Alpine CDA-117
    • JL 450/4v2 Active (Mid range, tweeters) JL 300/2v2 (Mid bass) DC 5K(Subs)
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
    • Singer 300 amp 15.1v bypass, 3 XS D3400s
    • DD M4a and XS D3100 coming soon
    • Viper 5701 with Smart Start
  6. #21
    Kevinl's Avatar
    Kevinl is offline Member
    Apr 2012
    Phoenix
    59
    Why are you saying your hid's draw a lot of power the kits are 35w and thats less than standard bulbs
    2005 Suburban
+ Reply to Thread
  1. another single sub vs dual sub question
    By lovephil in forum Subwoofers
    Last Post: 09-16-2010, 11:10 PM
  2. Single port vs dual
    By AudioEnthusiast in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 04-26-2010, 01:36 AM
  3. single sub vs. dual sub enclosure
    By big dawg in forum Enclosure Design & Construction Help
    Last Post: 07-14-2008, 11:01 PM
  4. Single Sub VS Dual Subs
    By NIUzer0 in forum Subwoofers
    Last Post: 03-21-2007, 01:50 AM
  5. Single 15 vs dual 12s.....
    By tweekerz in forum Subwoofers
    Last Post: 04-20-2004, 08:49 AM
Tags for this Thread
