+ Reply to Thread
Results 1 to 3 of 3
Reload Thread: 2 svc 4 ohms.. wiring help
    marksman711's Avatar
    marksman711 is offline Junior Member
    Mar 2013
    mi
    I have 2 12 kenwood svc 4 ohm 400 watt rms subs. a mono block amp Crunch P1-1050.1 which is 500 watt x1 4 ohm, 1000 watt x1 2 ohm. my box is a ported single chamber down middle. my box also has 2 terminals 1 on each side . how should I wire my subs to get the best performance.
    nvturbo's Avatar
    nvturbo is offline Member
    Nov 2012
    North Carolina
    77
    Re: 2 svc 4 ohms.. wiring help
    That's simple.
    Amp (+) ~~~~~~> (+) sub #1 ~~~~~~> (+) sub #2
    Amp (-) ~~~~~~> (-) sub #1 ~~~~~~~> (-) sub #2
    You can connect the wires (respectively) together at the amp if you dont want to get rid of your box. This will give you a 2ohm mono load. (1000 watts)
    2012 Volkswagen GTI 4dr
    * stock RCD-510 H/U
    * stock door speakers (for the time being)
    * Audison SR 1D monoblock amp
    * Rockford Fosgate P3SD4-12 12" in a 1.0ft^ custom-fab sealed enclosure
    * Streetwires OFC 4awg power/ground wires
    * Audio Control LC2i line output converter
    * Audio Control ACR-1 remote knob
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    5,118
    28
    127 Post(s)
    have you been helped by me? i'd love to know. shoot me a PM.
    My 2001 Accord build log:
    http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Can I help you? valencebandacoustics@gmail.com
    Want to learn about car audio electronics?
    http://www.bcae1.com
+ Reply to Thread
  1. Ohm wiring help
    By radrashad in forum Wiring, Electrical and Installation Help
    Last Post: 02-02-2012, 12:18 AM
  2. Dual 2 Ohm wiring help
    By threedd97 in forum Subwoofers
    Last Post: 01-11-2006, 12:04 AM
  3. DUAL 6 OHM wiring help
    By billy18bm in forum Wiring, Electrical and Installation Help
    Last Post: 01-08-2006, 10:41 PM
  4. 2 ohm wiring help
    By bumpn_gt in forum Wiring, Electrical and Installation Help
    Last Post: 09-11-2003, 08:28 AM
  5. ohm wiring help
    By eddie12345 in forum Wiring, Electrical and Installation Help
    Last Post: 01-05-2003, 10:23 PM
