Results 1 to 5 of 5
Reload Thread: Strapping and woofer ohm load
    xlcorylx's Avatar
    xlcorylx is offline Member
    Jan 2013
    westwego , La
    42
    17 Post(s)
    Is this correct???
    2-1ohm amps Strapped making it 2 ohms= Sub needs to be 2 ohms
    1-dvc 4ohm sub
    so i took both termial +'s and connected it to the master amp
    and took both -'s and connected it to the slave amp
    Is it going to be 2ohms all together?
    or 4 ohms lol ?
    n8skow's Avatar
    n8skow is offline CarAudio.com Elite
    May 2009
    Kansas City, MO
    1,291
    263 Post(s)
    Re: Strapping and woofer ohm load
    List what equipment your actually working with... (not all amps are strappable).
    Knowing what you've got will aid in knowing how to wire them... When strapping amps - each sees half the load, so if you've got a 2-ohm load, each amp will see 1-ohm.
    National Finals
    Oct. 28-29th, 2017 - Sedalia Missouri
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    depends on the amp . but if they are strappable .its master amp speaker + is the + from the sub,then the speaker - from the master amp to the - of the slave amp,then the speaker + from the slave amp to the - of the sub .you must also link the 2 amps .one master the other slave .
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
    xlcorylx's Avatar
    Jan 2013
    westwego , La
    42
    17 Post(s)
    thats al i wanted to here!
    Repoguy79's Avatar
    Repoguy79 is offline Junior Member
    Mar 2013
    Jersey
    6 Post(s)
    yepppp
  1. 2 channel amp and component ohm loads?
    By mark871214 in forum Speakers
    Last Post: 12-16-2008, 11:00 AM
  2. Sub Tuning and ohm load questions
    By 8inw7 in forum Subwoofers
    Last Post: 01-11-2005, 09:08 AM
  3. Hifonics and 1.5 ohm load
    By John3000 in forum Amplifiers
    Last Post: 03-07-2004, 01:12 AM
  4. 2 and 4 ohm loads
    By DaBaller504 in forum Wiring, Electrical and Installation Help
    Last Post: 02-16-2003, 04:59 PM
  5. Replies: 0
    Last Post: 04-27-2002, 09:29 AM
