Page 5 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 61 to 75 of 109
Reload Thread: running amp from cigarette lighter
  1. #61
    Oct 2012
    Southern ILL
    165
    2 Post(s)
    83 Post(s)
    Re: running amp from cigarette lighter
    Simmer down, Bro. What you need to understand is at some point your amp will have to draw all it's power through the cigarette lighter wire. And trust me the wire behind the plug is smaller gauge than that cord coming out. As your batteries run down you are actually running the amp on a piece of 18 gauge wire behind the dash. STOP THIS! The only reason this has worked so far is because your batteries are sort of acting like a buffer on the amp draw. As soon as the current demand exceeds what the batts have left, that little wire has to take up the slack in supplying the juice. IT CAN NOT DO THIS! IF THE FUSE DON"T POP THE WIRE WILL BURN!!! GO TO WALMART OR WHEREVER AND GET PROPER WIRE!!!!!!!! Make 2 runs, one for pos and one for neg from your battery. That way you dont have to modify anything at all and your good to go.
    Quote Originally Posted by Jeffdachef View Post
    If your subs seem like they are slow that means you need Time Alignment a feature in sound quality based head units. A good head unit makes the biggest difference because it'll make the subs and speakers match up at the same speed with the time alignment feature.
  2. #62
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Quote Originally Posted by soundstream16 View Post
    i am well aware of what to do and thanks for not being a jerk about it. i did a system in my friend's avenger and it has been great for him. my definition of modifying would be swapping something out, replacing something, or changing what is stock.
    Dude, not to be a dick, but if you did his install like this, you have no business doing installs in someone else's car. You got lucky here, but what would you do if your buddies car burned to the ground?
    So as mentioned, if you did it right no one would know these wires were there. All you are doing is adding 5 wires, 4 if you want to go easy. You need one long one that will run from front battery to rear battery (fused), one to run from your battery positive to your amp positive (fused), one to ground your amp to your battery, and one to ground your battery to your frame. You also will need a remote wire for your amp, but you could jump your positive wire there if you didn't want to add more.
  3. #63
    soundstream16's Avatar
    soundstream16 is offline Member
    Mar 2013
    Huntington Woods, MI
    30
    12 Post(s)
    thanks to everyone who helped my out. i am goanna get it done right this time.
    current system
    -Soundstream SPLX-152 HF
    -Soundstream TX1.2000D
    -Soundstream SST-05 super tweets
    -Custom box built by me tuned to 32 HZ
    -Kinetik Batts
    -2007 ford focus ses hatchback
  4. Likes Serpent710 liked this post
  5. #64
    Mar 2013
    30
    12 Post(s)
    Quote Originally Posted by gckless View Post
    in my friends car we ran power wire, second batt with an isolater, replaced all door pods and ran it off of a 4 channel amp, and i put in
    2 12'' soundstream tsq 12's. i did it right
    edit: also an in line 100 amp fuse 6 inches from the batt.
    current system
    -Kinetik Batts
  6. #65
    Oct 2012
    Southern ILL
    165
    2 Post(s)
    83 Post(s)
    Quote Originally Posted by Snapper_Slapper View Post
    Just so we're clear, run the proper wire from your main battery under the hood. The one that starts the car n such.
  7. #66
    Mar 2013
    30
    12 Post(s)
    well i charge the batt on a regular basis so that is probably why it has worked. but ya. im goanna wire it up the right way
    current system
    -Kinetik Batts
  8. #67
    Mar 2013
    30
    12 Post(s)
    yes i know. i did a system in my friends car. we added a second batt with an isolator also. also did the big three. i have a clue what im doing. but i am still learning too.
    current system
    -Kinetik Batts
  9. #68
    shadow's Avatar
    shadow is offline Senior VIP Member
    Jan 2012
    Dallas,Texas
    243
    84 Post(s)
    listen between all the distortion Brah And run a proper fused power wire and ground. (No it's not A Mod.)
    No more then what you have now. It will be safer so you will have a car when you Graduate...
    If not get a fire extinguisher your going to need it!!!
  10. Likes Jes 42 liked this post
  11. #69
    Mar 2013
    30
    12 Post(s)
    Quote Originally Posted by shadow View Post
    thanks. i will run proper power wire. and i happen to have a fire extinguisher in my car lol.
    current system
    -Kinetik Batts
  12. #70
    Dtrom's Avatar
    Dtrom is offline MAF
    Jul 2012
    3,996
    1190 Post(s)
    Awesome
    REFS alot
  13. Likes wickedwitt liked this post
  14. #71
    Ge_off_me's Avatar
    Ge_off_me is offline I sound better than you
    Apr 2010
    Enon, Ohio
    27
    6,684
    2 Post(s)
    720 Post(s)
    Best.Read.Ever.10/10.Would.Bang.
    Home AV Product Manager - Parts Express
  15. Thanks brooklynjoy2008 thanked for this post
    Likes brooklynjoy2008, Dtrom, wickedwitt liked this post
  16. #72
    Slo_Ride's Avatar
    Slo_Ride is offline Take It Easy
    Oct 2005
    Back to ATL
    13,028
    33 Post(s)
    3127 Post(s)
    what happened to the vids? I really wanted to see this.
    Refs = PapaGeno21, Goindef154, 92c1v1c, Disarmer, chemmins, 97maxima, kroid777, ithertz, basscort2009, hunterw, mar08052, appleyard, millimac247, jonny101abc, sundownz, cranberryyumyum, mig139, daboyfrumdabx, skateguy92, basebalz13.
  17. #73
    khaoskilroymma's Avatar
    khaoskilroymma is offline Junior Member
    Feb 2013
    Moline, IL
    29
    13 Post(s)
    i have 3 comments...
    1: WOW
    2:im sure if whoever owns the car knew about the eletrical hazards your building now they would gladly let you "modify" it.
    3: if it is going to be ur car when u graduate but they wont let u do anything to it yet.. then they're obviously nervous you might not graduate so they dont want you screwing up their car... and by your install capabilites i completely understand why they would be worried about you graduating or not
  18. Thanks RicksI30 thanked for this post
    Likes Dtrom liked this post
  19. #74
    Better-Action's Avatar
    Better-Action is offline give me a reach around
    Sep 2012
    SD
    438
    167 Post(s)
    What happened to the vids of your "slamming" setup?
    Bought from Underfire, Stephens30228, audiobaun.
  20. Likes brooklynjoy2008 liked this post
  21. #75
    RicksI30's Avatar
    RicksI30 is offline CarAudio.com Elite
    May 2011
    Tucson, Az
    29
    588
    189 Post(s)
    Quote Originally Posted by khaoskilroymma View Post
    1: Wow
    3: If it is going to be ur car when u graduate but they wont let u do anything to it yet.. Then they're obviously nervous you might not graduate so they dont want you screwing up their car... And by your install capabilites i completely understand why they would be worried about you graduating or not
    #2 x 1,000,000
    Head unit: Kenwood Excelon KDC-X996
    Front stage: Alpine Type X PRO mids Vifa Neo 1" silk tweeters
    Front stage amp: PPI Bk800.4
    Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
    Sub amp: PPI Bk1300.1
    Sound Deadening: Second Skin Damplifier Pro, Spectrum, and Sludge
    Team SSA
  1. How to run amp from OEM Navi/ OEM Amp?
    By subydude81 in forum Wiring, Electrical and Installation Help
    Last Post: 07-20-2009, 08:55 PM
  2. Tap off Cigarette Lighter for Amp Remote Wire?
    By DaBurner in forum Wiring, Electrical and Installation Help
    Last Post: 01-15-2007, 04:49 PM
  3. How to run wires from Sub to amp
    By TheSpeakerMan in forum General Discussion
    Last Post: 06-04-2006, 03:03 AM
  4. how do you guys run wires from amp to door?
    By SmokeAlot in forum Speakers
    Last Post: 06-13-2005, 10:45 PM
  5. Can i run two amps from one remote wire?
    By loudfivepoint0 in forum Wiring, Electrical and Installation Help
    Last Post: 08-15-2004, 02:06 AM
