Page 4 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 46 to 60 of 109
Reload Thread: running amp from cigarette lighter
  1. #46
    eli346's Avatar
    eli346 is offline Member
    Dec 2012
    United States
    104
    48 Post(s)
    Re: running amp from cigarette lighter
  2. #47
    soundstream16's Avatar
    soundstream16 is offline Member
    Mar 2013
    Huntington Woods, MI
    30
    12 Post(s)
    Quote Originally Posted by Serpent710 View Post
    "Remember to get white stitched ones with 11mm of Xmax....They are the best" and use a cell phone charger as power wire for xtra bass
    i told u they were not even my subs. i was borrowing them. trust me, those Q power subs were not good at all. i would never recommend them. and it was not cell phone charger wire. it was ten gauge to the batts, 8 gauge to the amp.
    ---------- Post added at 10:12 PM ---------- Previous post was at 10:11 PM ----------
    Quote Originally Posted by Better-Action View Post
    You have two 8 amp Batts running of your cigarette lighter. Cigarette lighters are fused at what 10 amps? Sounds like you may be pushing a ear rapin' 100 Watts of powa!
    And in your words.... "it slams!" Erma gerd
    it slams for what it is. and i have completly different batts now. actually batts.
    current system
    -Soundstream SPLX-152 HF
    -Soundstream TX1.2000D
    -Soundstream SST-05 super tweets
    -Custom box built by me tuned to 32 HZ
    -Kinetik Batts
    -2007 ford focus ses hatchback
  3. Dislikes ThatChevyGuy disliked this post
  4. #48
    Mar 2013
    30
    12 Post(s)
    Quote Originally Posted by juanmgarza26 View Post
    im pretty sure the wait is worth it man... come on don't risk this car burning up on you man like seriously...
    well hopefully i can work something out and run actuall power wire. if not, i will pull my equiptment out and save it. but can i atleast get people on here to agree that running power wire is not "modifying" the car so i have proof.
    current system
    -Kinetik Batts
  5. #49
    MutantDreams's Avatar
    MutantDreams is offline Senior VIP Member
    Apr 2012
    Columbus, Georgia
    261
    64 Post(s)
    If it is done properly it is not modifying the car. That's what wire loom is for. It should be all ran under the carpet/zip tied etc. realistically you shouldn't even know there is power wire ran at all.
  6. Thanks soundstream16 thanked for this post
    Likes wickedwitt, soundstream16 liked this post
  7. #50
    Knowmadic's Avatar
    Knowmadic is offline Senior VIP Member
    Feb 2013
    Winchester, VA
    499
    1 Post(s)
    159 Post(s)
    Running power wire isn't modifying your car at all.. You're hooking a metal circle to a battery post, running the wire through the car to the amp and enjoying decent bass. Not risking your car burning down is a great arguing point you can use.
  8. Thanks soundstream16 thanked for this post
    Likes soundstream16 liked this post
  9. #51
    Mar 2013
    30
    12 Post(s)
    ok. this thread has went no where fast. let me clear some things up. the subs in the vid were crap and were not mine, i am well aware the install is crap. i know all of this.
    please help me on one thing.
    please agree that running power wire is not modifying the car so i have proof it isn't. it is the same thing as running it from the cigarette lighter. technically, it is just "plugging something in". please agree on that
    current system
    -Kinetik Batts
  10. #52
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Quote Originally Posted by soundstream16 View Post
    Well what is your definition of "modifying the car"? You gave that stipulation, so you should be the one defining it. I would not consider it to be modifying the car.
    I am glad that you genuinely are looking for help. My advice is to unplug those wires from your cigarette lighter right now. Don't plug it back in. You need to get a proper run of wire from your front battery to your rear. 4ga wire, with proper fusing. You also need to ground your rear amp. And you are also going to need a remote wire. There's a couple places you could take it from behind the dash.
  11. #53
    Mar 2013
    30
    12 Post(s)
    Quote Originally Posted by MutantDreams View Post
    EXACTLY! thank you. everything hidden under the trim. everything CLEAN
    current system
    -Kinetik Batts
  12. #54
    Knowmadic's Avatar
    Feb 2013
    Winchester, VA
    499
    1 Post(s)
    159 Post(s)
    OP refer to the post directly above this one.
  13. Likes soundstream16 liked this post
  14. #55
    Better-Action's Avatar
    Better-Action is offline give me a reach around
    Sep 2012
    SD
    438
    167 Post(s)
    If you have to beg your mom to allow you to run a wire then its best you just wait Sonny. Don't worry man in 7 years when you graduate you'll be ready for a nice setup and will actually have the brainpower to not do **** like this. Its for the best.
    Bought from Underfire, Stephens30228, audiobaun.
  15. #56
    Mar 2013
    30
    12 Post(s)
    Quote Originally Posted by gckless View Post
    i am well aware of what to do and thanks for not being a jerk about it. i did a system in my friend's avenger and it has been great for him. my definition of modifying would be swapping something out, replacing something, or changing what is stock.
    current system
    -Kinetik Batts
  16. #57
    Mar 2013
    30
    12 Post(s)
    If you have to beg your mom to allow you to run a wire then its best you just wait Sonny. Don't sorry man in 7 years when you graduate you'll be ready for a nice setup and will actually have the brainpower to not do **** like this. Its for the best.
    im so sick of your crap. i know what i am doing. but i am still learning. i'll admit that. also, i don't have to beg anyone. i have to prove running wire is not modifying the car. proving something is different than begging. also, how do they let people like you stay on the forum. seriously
    current system
    -Kinetik Batts
  17. #58
    Sep 2012
    SD
    438
    167 Post(s)
    I'm betting that car didn't come stock with an amplifier running off your cigarette lighter. So by definition you have modified it... terribly.
  18. Likes robert420 liked this post
  19. #59
    whitedragon551's Avatar
    whitedragon551 is offline Moderator
    Mar 2009
    IL
    13,601
    42 Post(s)
    1434 Post(s)
    If you ran the wire properly nobody would even know it was there.
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
  20. #60
    darron016's Avatar
    darron016 is offline Senior VIP Member
    Dec 2012
    minneapolis, mn
    392
    294 Post(s)
    Hey man better-action is a dicck and the whole forum knows it..
    Don't take it personal
  21. Likes Better-Action, soundstream16 liked this post
  1. How to run amp from OEM Navi/ OEM Amp?
    By subydude81 in forum Wiring, Electrical and Installation Help
    Last Post: 07-20-2009, 08:55 PM
  2. Tap off Cigarette Lighter for Amp Remote Wire?
    By DaBurner in forum Wiring, Electrical and Installation Help
    Last Post: 01-15-2007, 04:49 PM
  3. How to run wires from Sub to amp
    By TheSpeakerMan in forum General Discussion
    Last Post: 06-04-2006, 03:03 AM
  4. how do you guys run wires from amp to door?
    By SmokeAlot in forum Speakers
    Last Post: 06-13-2005, 10:45 PM
  5. Can i run two amps from one remote wire?
    By loudfivepoint0 in forum Wiring, Electrical and Installation Help
    Last Post: 08-15-2004, 02:06 AM
