Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 31 to 45 of 86
Reload Thread: Odd subwoofer "breathing" when sound stops should I be worried?
  1. #31
    brooklynjoy2008's Avatar
    brooklynjoy2008 is offline CarAudio.com Elite
    Oct 2011
    ohio
    611
    209 Post(s)
    Re: Odd subwoofer "breathing" when sound stops should I be worried?
    Can you sell me your amp? I have cash!
  2. #32
    gamehawk55's Avatar
    gamehawk55 is offline CarAudio.com Elite
    Nov 2012
    Victoria BC, Canada
    31
    534
    230 Post(s)
    Quote Originally Posted by brooklynjoy2008 View Post
    This only happens on some tracks right. If so delete one of those tracks, download it again, and see if it still happens.
    Like I said it happened EVERY time each of the test tones ended (30hz all the way to 40hz). As in going from high excursion to instant off. So it can't have anything to do with the track because its only seen when the track has ENDED (as in no sound). It's not like the test tone has ended and is still playing something at the end that's causing the "breath". It's OFF and loading the next track on the USB stick.
    Vehicle: 2007 Pontiac G6 GT
    Head Unit: Kenwood DDX419
    Speakers: Focal PS165 Components
    Distribution: Knukonceptz KNF-60 Power/Ground Distribution block
    Amps: Audioque 200.2, Rockford Fosgate T2500-1BDCP
    Subs: 2 SA-8v2 D2 wired @2ohms in custom ported box tuned to 34-35hz
    Wiring: All 1/0 Gauge SHOK Wire and Knukonceptz wire + BIG 3
    Alternator: Singer 310A 6 Phase High Output Alternator
  3. #33
    gamehawk55's Avatar
    Nov 2012
    Victoria BC, Canada
    31
    534
    230 Post(s)
    I could. Depends what you are offering. That is if you're serious lol. I've been wanting to upgrade to a more powerful sub amp since getting the SA-8s and will probably end up getting a 3rd or 4th eventually and 1150W just wont cut it for 4 of these bad boys haha.
    I've actually been meaning to list the amp here just havent gotten around to taking the pics with the username/date sign yet.
  4. #34
    gamehawk55's Avatar
    Nov 2012
    Victoria BC, Canada
    31
    534
    230 Post(s)
    If you wanna see it in action check out my YouTube channel
    Kalin Kruger - YouTube
    Got a bunch of new vids up of it running the SA-8s
  5. #35
    jdawg's Avatar
    jdawg is offline CarAudio.com Veteran
    Jun 2006
    Maryland, United States
    8,582
    61 Post(s)
    Quote Originally Posted by gamehawk55 View Post
    Again see sig. Amp is a Audison LrX 5.1k. The most powerful 5 channel amp audison ever made. And when it was in production it was over $2000 amp. So if that's a poop amp I'd hate to see what is an excellent 5 channel amp
    I have sigs off
    You don't have your highs damped too? If so look at the woofer cones in your doors. You could grab some rcas and run them just over the seats and ****, real quick, that would eliminate that, put the same tracks on your ipod, get a 3.5mm to rca adaptor at walmart or radio shack or wherever and plug it direct into the amp, if it still does it then I would say its the recording or the amp or ground spots, if it goes away then its the rcas or deck or the decks ground or the rca picking something up in the dash. Bro you are just going to do some diagnostics and eleminate some things. So get moving!
    refs
    woc47, nigro013, defconx3, louisiana_crx, bld 25, supa_c, lancer1978, sxkicker89, 310w6, more, i forget
  6. #36
    gamehawk55's Avatar
    Nov 2012
    Victoria BC, Canada
    31
    534
    230 Post(s)
    Quote Originally Posted by jdawg View Post
    I have sigs off
    Amping these current door speakers would be a PITA as they are part of the Premium Monsoon system. So mids/tweets, 6x9's, more tweets in rear. Would be a PITA for me to try and wire all that to my 5 channel and make it work properly. Speaker impedances in the monsoon system are weird to use with aftermarket amps from what I've read. Needs modification and extra caps and stuff. And I'm not skilled enough to pull it off myself. Hence why I've got some Focal PS165's coming for the front.
  7. #37
    Oct 2011
    ohio
    611
    209 Post(s)
    Again if it only happens on those test tones I would not worry about it. Does it happen on any music?
  8. #38
    gamehawk55's Avatar
    Nov 2012
    Victoria BC, Canada
    31
    534
    230 Post(s)
    Sometimes it can be seen briefly while playing certain songs that have hard hitting quick notes. Like Echo by Gorilla Zoe. The quick notes at the beginning before the drop hits is a good example. If the notes hit hard enough the sub can be seen briefly "re-aligning" between notes.
  9. #39
    jdawg's Avatar
    Jun 2006
    8,582
    61 Post(s)
    Something. Is wrong. You have to start eliminating things. Plugging your ipod direct to your amp will eliminate everything forward of the amp, the rcas and deck. If it goes away then your problems are somewhere from your rca forward. Reread what I posted. You have to go, do some work and start eliminating things. There is no magical answer.
    refs
  10. #40
    gamehawk55's Avatar
    Nov 2012
    Victoria BC, Canada
    31
    534
    230 Post(s)
    Plugging the Ipod in directly to the amp. Would I be able to get the proper amount of signal that way to even get the subs to get full power? If so I can try that tomorrow. I have a 3.5mm to RCA jack in the back of my computer and have a 1ft RCA in the car :P:
  11. #41
    Oct 2011
    ohio
    611
    209 Post(s)
    Danm bro you get down on the guitar!!
  12. #42
    gamehawk55's Avatar
    Nov 2012
    Victoria BC, Canada
    31
    534
    230 Post(s)
    Haha. Thanks man. Been playin for about 8 years or so. It's a lot of fun :P: Sent ya a PM about the amp if ur serious btw.
  13. #43
    sbarber82's Avatar
    sbarber82 is offline CarAudio.com Elite
    Dec 2012
    Vegas baby
    35
    520
    162 Post(s)
    I have had subs do this before and it came down to bad rca's. They were picking up a signal from something. I am not saying your rca's are bad but it could be the culprit.
    Ride:2009 Silverado Crew Cab
    H/U: Pioneer avh-p4400bh
    Amps: Ampere Audio 3800.1 Ampere Audio 125.4
    Subs: 2 Tantric HDD 15's
    Enclosure: 4th Order Blow Through
    Mids/Highs: Tantric HD
    Singer 320 Hairpin 6 phase
  14. #44
    Oct 2011
    ohio
    611
    209 Post(s)
    Yeah if you are getting it while the music is playing something is wrong. I would start eliminating things.
  15. #45
    jdawg's Avatar
    Jun 2006
    8,582
    61 Post(s)
    You will probably have to crank the gain cause of the lower voltage but it shouldn't matter if its doing it at all volumes
    refs
  1. Odd Noise When I Stop & Go
    By Slammed in forum Car Performance and Repair
    Last Post: 02-12-2009, 12:01 AM
  2. Kenwood Excelon has an odd subwoofer
    By KenExc2007 in forum Wiring, Electrical and Installation Help
    Last Post: 01-01-2007, 11:11 AM
  3. When sound deadening, outer and inner skin?
    By 02envoy in forum General Discussion
    Last Post: 07-03-2005, 03:17 PM
  4. When sound deading a trunk...
    By ThumpinCRX in forum General Discussion
    Last Post: 01-20-2003, 05:32 PM
  5. "Esoteric" components
    By 89S4 in forum Amplifiers
    Last Post: 01-23-2002, 07:03 PM
