I was wondering if I could wire my two Memphis 15-PR12D4v2 subs to one ohm without blowing them. Kind of new to this so sorry in advance.
Yes do wire them each 2 ohm the connect the pos n neg together n then to the amp
Do you have a wiring diagram for that?
Would this work also?
Yes, it's the same thing.
Doing this wont hurt my spaekers?
After I wire my subs this way should i do the square root of 4000 or the square root of 1200? My amp says this.
•RMS Power Rating:
◦4 ohms: 300 watts x 1 chan.
◦2 ohms: 600 watts x 1 chan.
◦1 ohm: 1000 watts x 1 chan
Anybody?
Help please
As long as you wire it exactly as that diagram shows, your amplifier is 1ohm stable, and you set your gains properly then your subwoofers will be fine.
Bookmarks
