Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Reload Thread: My front speakers keep blowing! Please help!
  1. #16
    whitedragon551's Avatar
    whitedragon551 is offline Moderator
    Mar 2009
    IL
    13,566
    40 Post(s)
    1410 Post(s)
    Re: My front speakers keep blowing! Please help!
    Quote Originally Posted by Knowmadic View Post
    First off, why did you pay to get those fixed, there are these new things called warrantys. After the second time it blew I would fire your installer and make him pay for speaker replacement/repair since you didn't buy a warranty and still didn't get one after the 2nd blown pair. I'm going to say he's a dirty liar and the amps gain is not properly adjusted, what amp is it? Have you tried turning it down or tuning it personally, it's quite simple and cost less then 5 pairs of speakers. The installer doesn't know whats going on or what he's doing from what it sounds like.
    TL;DR = Tune yourself and what type of wire, gauge of wire, and what amp?
    Last resort = Aftermarket HU
    Warranty doesnt cover improper installation which includes blowing products.
    The issue is the gain is to high or head unit settings are wrong causing clipping/distortion and blowing the speakers.
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
  2. Likes jtomsic liked this post
  3. #17
    Sub Woofin's Avatar
    Sub Woofin is offline CarAudio.com Elite
    Mar 2011
    California
    31
    1,490
    290 Post(s)
    dat power wire
    Ca & Caco Refs: its_bacon12, acex3a, boilermaker-744, howyadoin, Ajax_6154, Pro-Rabbit, jr711, Starky, Ledoux289, AKHeathen, Dirtrider4eva, mast240, gumby688
  4. #18
    Serpent710's Avatar
    Serpent710 is offline CarAudio.com Veteran
    Feb 2008
    Florida
    2,652
    564 Post(s)
    electrical tape sex
    Refs: mike11202, Tehgregzor, Twisted_0912, Goindef154, fasfocus00, got_focus?, Boswell59, 2lows10, skateguy92, Worstenemy453, Supergumby5000, gboo559, ryanm923, GetLikeMe, TaylorFade, Dacheatham, pickup1, jerseyboy, TWiZTiD859, Kangaroux, 09civic
    Sub: 2 12" Cerwin Vega Vmax
    Comps: Boston
    Enclosure: Birch Bitch
    Amp: JBL Crown BPx1100.1
    H/U: Pioneer Premier FH-p800bt
    Wiring: Stinger HPM
  5. Likes jtomsic liked this post
  6. #19
    Better-Action's Avatar
    Better-Action is offline give me a reach around
    Sep 2012
    SD
    438
    167 Post(s)
    Your installer screwed you over.
    Bought from Underfire, Stephens30228, audiobaun.
  7. Thanks jtomsic thanked for this post
    Likes jdawg90 liked this post
  8. #20
    Below20hzonly's Avatar
    Below20hzonly is offline CarAudio.com Elite
    Feb 2012
    East Grand Forks, MN
    897
    274 Post(s)
    his problem is probably that his crossover on the amp is set to FULL and not HPF thats what it looks like to me
    Quote Originally Posted by gckless View Post
    Is your gain level all the way up? If it is, that is the reason why you are blowing speakers, you don't have to look for anything further.
    Pioneer 80prs
    2 JL audio w6v.2s 12"
    Custom Baltic birch box. 31hz.
    Sundown saz1500d.
    Crossfire tek1002
    Knu and monster wiring
    *need two 6.5 coaxs
    Two 6x9,s
    HO alt for 95Honda accord
  9. #21
    Mar 2009
    IL
    13,566
    40 Post(s)
    1410 Post(s)
    Quote Originally Posted by Below20hzonly View Post
    Gain is still set improperly and clipping his speakers causing them to blow.
    CA.com FAQ's
    Forum Rules
  10. #22
    Go2Sleep's Avatar
    Go2Sleep is offline CarAudio.com Veteran
    Jan 2008
    Bay Area, CA
    30
    3,447
    98 Post(s)
    Pretty much you're clipping your speakers to ****. Besides having the crossovers and gains set properly you're most likely clipping right at the source (stock headunit). Set the bass and treble to flat and use a device such as a Steve Meade designs DD-1 to find the max clean signal... That or buy an aftermarket head unit!
    * (2) Morel Ultimo 12's * Hybrid Audio Legathia SE 3-Way Active Front Stage * RF 360.3 DSP * (2) Arc Audio XDi 1100.1 * Arc Audio XDi 1200.6 *
  11. #23
    DARKHART's Avatar
    DARKHART is offline One Hitter Quitter
    Aug 2002
    LITTLE ROCK, AR
    2,290
    197 Post(s)
    You don't need to buy an aftermarket headunit, you just to need to make sure that the levels are properly set on the intergration unit and on the amp as been previously stated. 80% volume on the factory deck should still yield a clean signal, find yourself a new installer and have your system gone over by someone qualified to do the job because it's obvious that your current guy isn't up to the job. Also you should be able to hear when you are distressing your drivers no matter if it's by overpowering or distorting them so back off the volume knob some and if it's still not loud enough for you then you may need to add a second pair of drivers with equal power....
    Just when they though it couldn't get any worse, in came the Lord of Kaos, the Darkhart has arisen from his century long slumber..
    ____________
    refs:
    Type-S Texan ............Xtremebass5
    NE14MX ........Grinder1989
    NJack2AF
    .............Jameseypoo
    Randyrsx ..........Bagdntagd
    M3Transporter......Teggybwoy
    RJ Sclafani...........Zeuslicious
    Saltyreefguy........Qkassidyw
    Qtrhorse..............Nismos14
    Pistonsfan70........4nine
    SlainNothing.........Orangelss
    [email protected]............Louisiana_CRX
    SW9152..............DukeNut
  1. Fuse keep blowing please help!
    By florida904 in forum Wiring, Electrical and Installation Help
    Last Post: 04-17-2010, 12:54 PM
  2. My front left speakers keep blowing!!!
    By greeneye7 in forum General Discussion
    Last Post: 12-28-2007, 12:10 AM
  3. Help please, my inline fuse keeps blowing.
    By jd1982 in forum Wiring, Electrical and Installation Help
    Last Post: 11-10-2007, 11:05 PM
  4. Fuses keep blowing, please help
    By V6beretta31L in forum Amplifiers
    Last Post: 05-09-2005, 08:20 PM
  5. help front speakers keep blowing!!!
    By lAciDl in forum Speakers
    Last Post: 06-07-2003, 02:38 AM
