+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Reload Thread: Help subs not pounding
  1. #16
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    31
    12,096
    351 Post(s)
    Re: Help subs not pounding
    Quote Originally Posted by Warmachine9210 View Post
    So u think there is a problem I have a mono block with two terminals I had each sub wired in series goin to there own terminal and it sound deep and hit hard
    I don't think there is an issue at all. I personally think you had the settings far to high and the shop turned them down.
    Your amp may have two terminals, but it is actually only one. It has two for making wiring easier.
    If you think the wiring is not right, then pull each sub and verify how it is wired. Then check the wiring from the box to the amp.
  2. #17
    Warmachine9210's Avatar
    Warmachine9210 is offline Member
    Feb 2013
    Topeka,ks
    41
    I required them to series parallel this mornin and then the shop tuned them so I'm guessin they playin it safe but I can't go over 35 on my head unit cuz that where they maxxed my tuning
  3. #18
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,096
    351 Post(s)
    What subs do you have and what coil config?
  4. #19
    Feb 2013
    Topeka,ks
    41
    Alpine type r 1st gen and 2 ohm dvc
  5. #20
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,096
    351 Post(s)
    You are wiring to 2 ohm I would take it?
    If so, then yes series each sub then parallel them to the amp.
  6. #21
    Feb 2013
    Topeka,ks
    41
    I did that I have ran series parallel and still sound lower
  7. #22
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,096
    351 Post(s)
    Then it is likely settings that were altered to keep your setup safe from damage.
  8. #23
    Feb 2013
    Topeka,ks
    41
    I'm gonna jus sell em or find someone that will trade me
  9. #24
    Feb 2013
    Wisconsin
    45
    Why give up so easy? There's nothing wrong with the subs. It's in your electrical. So selling your subs won't fix that problem. Check out your amp settings. I'm sure that will do the trick.
  10. Likes Warmachine9210 liked this post
  11. #25
    Feb 2013
    Topeka,ks
    41
    See that the thing I'm new to this and idk if the amp to high or wat I have a crunch 2000 watt 2050.1 amp to those subs amp is set at 2.25 voltage and barely any gain like the shop left it and they don't bump what should I do
    ---------- Post added at 11:07 PM ---------- Previous post was at 11:07 PM ----------
    It's the brand new amp by crunch powerone
  12. #26
    Bigmann6374's Avatar
    Bigmann6374 is online now Senior VIP Member
    Oct 2012
    Moon, PA
    294
    1 Post(s)
    I have owned this amp and made the same mistake man... THat amp puts out 500 watts at 2 ohms not 1000 like you would expect. To get anything out of it you have to wire to 1 ohm.
  13. #27
    Feb 2013
    Topeka,ks
    41
    I jus traded them for two 12 inch fosgate punch hx2 and got them wired at 1 ohm
  14. #28
    Feb 2013
    Topeka,ks
    41
    And I jus got a flip out screen and at a cold start the fan in the headunit makes a squealing noise but after a few mins it goes away is it doing this jus from being cold
+ Reply to Thread
  1. Please Help....sub not playing..help
    By bow125106 in forum Wiring, Electrical and Installation Help
    Last Post: 05-16-2008, 06:31 PM
  2. Need some help sub not turning on
    By Talamant3z in forum Wiring, Electrical and Installation Help
    Last Post: 02-10-2008, 06:24 PM
  3. HELP! sub not doing anything! (pics)
    By perfecxionX in forum General Discussion
    Last Post: 02-04-2007, 03:30 AM
  4. HELP! sub not doing anything! (pics)
    By perfecxionX in forum Wiring, Electrical and Installation Help
    Last Post: 02-03-2007, 10:43 PM
  5. AHHH HELP... Sub not working correctly
    By Honda_civic in forum General Discussion
    Last Post: 03-31-2004, 05:28 PM
