Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Reload Thread: Second Battery Questions
  1. #16
    SBFandy's Avatar
    SBFandy is offline Member
    Feb 2013
    Wisconsin
    42
    23 Post(s)
    Re: Second Battery Questions
    Quote Originally Posted by bgowdy31 View Post
    I would try to make sure i stay about atleast 12v while playing
    Thanks for the help man!
  2. #17
    bgowdy's Avatar
    bgowdy is offline HE NEEDS SOME MILK
    Apr 2011
    Campbellsville, Ky
    7,768
    82
    2 Post(s)
    2447 Post(s)
    Quote Originally Posted by SBFandy View Post
    No problem... How big is your stock alt
    [B]02 KIA SPORTAGE
    2 Sundown SA 12 Dual 4's
    Enclosure: 4 Cubes Net @ 34ish Hz
    Soundstream Ta.3kw @ 1 ohm
    Stock 70a Alt ~ XS D3400 & 1 Kinetic HC1800 ~ 2 Runs Bullz Audio 1/0 ~ Bullz 1/0 Big 3
    Current Build Score ~ 143.5 On The Dash
    F.C.B.C. > 2010 450 Street 3rd Place Overall > 2011 450 Street Champion
    YOUTUBE SEARCH->bgowdy31 & bgowdy3131
  3. #18
    Oct 2012
    Whitecourt, Alberta
    41
    16 Post(s)
    ..........lool
    laugh at me...why? stating facts. If you connect two different batteries, in two different charge states, the lesser charged one will benefit from more charged.
    quiescent current.....the larger battery has a bigger quiescent current and that's the current that is required to just stay at status quo it will see the smaller battery as a food source.....and then you have a dead battery. I think they should be within 100 amps of each other to connect and connecting a deep cycle battery with a typical lead acid battery...well im not to sure what the consequences would be. Just saying!!
  4. Likes robert420 liked this post
  5. #19
    robert420's Avatar
    robert420 is offline Senior VIP Member
    Dec 2012
    geneva ne
    338
    86 Post(s)
    you could just mount a second alternator n run that cable straight to the rear battery... less risk for fire, battery drainage, alt. damage n all that kinda ****
  6. #20
    bgowdy's Avatar
    Apr 2011
    Campbellsville, Ky
    7,768
    82
    2 Post(s)
    2447 Post(s)
    Quote Originally Posted by dunerider650 View Post
    i agree that this is the rule of thumb. However as i was saying before this is not always true. I have ran mismatched batteries before and i am now. before on a stock alt i ran a duralast gold under the hood, and regular lead acid battery in back as well a deep cycle marine. i never had trouble with them for more then a year. voltage was pretty good considering i had a 100a stock alt(Which i still have and works like new). Even now i still have the duralast gold under hood with a 220a HO alt and in back now i have 3 deka 105ah agm batteries and my voltage rests at 12.8v and runs between 14.6v - 15.0v depending on the temperature. at full tilt with 3850rms @ 1 ohm i stay above 13.7v @ idle.
    But i do understand what your saying. that is the "Rule of Thumb".... I was just saying from MY exp.
    [B]02 KIA SPORTAGE
  7. #21
    Oct 2012
    Whitecourt, Alberta
    41
    16 Post(s)
    [QUOTE=bgowdy31;8333579]i agree that this is the rule of thumb. However as i was saying before this is not always true. I have ran mismatched batteries before and i am now. before on a stock alt i ran a duralast gold under the hood, and regular lead acid battery in back as well a deep cycle marine. i never had trouble with them for more then a year. voltage was pretty good considering i had a 100a stock alt(Which i still have and works like new). Even now i still have the duralast gold under hood with a 220a HO alt and in back now i have 3 deka 105ah agm batteries and my voltage rests at 12.8v and runs between 14.6v - 15.0v depending on the temperature. at full tilt with 3850rms @ 1 ohm i stay above 13.7v @ idle.
    I completely get what your saying.... and having done it yourself you would know the "real life" issues that might happen. Ive known people to do it as well...just thought i would get into a bit more detail on the matter for SB since this topic got brought up.
  8. #22
    SBFandy's Avatar
    Feb 2013
    Wisconsin
    42
    23 Post(s)
    Or i can relay them......
  9. #23
    Oct 2012
    Whitecourt, Alberta
    41
    16 Post(s)
    yep use an isolator....then it doesnt matter.
  10. #24
    urmomsmin3's Avatar
    urmomsmin3 is offline Senior VIP Member
    Jan 2013
    balto
    177
    37 Post(s)
    i just put a 2nd bat in i have a fuse 12 inches from the first bat goin to the second one then another fuse 10 inches from 2nd bat to my amp ground the 2nd bat to the frame or floor w.e just make sure its a good ground
  11. #25
    garretttt4's Avatar
    garretttt4 is offline big pimpin
    Aug 2012
    Watertown sd
    2,456
    1 Post(s)
    1027 Post(s)
    Quote Originally Posted by robert420 View Post
    why would he mount a second alt for a measly 2000 watts? if he was gunna get another alt he could just get one h.o. alt and be more than fine.
    01 Silverado 2500hd
    Four custom mmats juggernaut 12's. (For sale, or trade for two beefy 12's or 15's)
    Bought from: Jayzbent, mylows10, logan527, Timmy13091, wingsfreak9, Underfire
    Traded with: mylows10(x2), knowmadic
    Sold to: 03silverado03, foomanchu, heel4lyfe, Timmy13091, wErd
  12. #26
    JoeK's Avatar
    JoeK is offline CarAudio.com Elite
    Apr 2012
    Ringtown, PA
    23
    1,055
    412 Post(s)
    Isolators cause more harm to batteries than good. When you instantly charge up that drained battery you are not only causing premature death of the front batt, but increasing the strain on the alternator.
    2003 Jeep Liberty Sport
    2x DC Audio XL 12
    2x SK-1500.1s strapped
    Tenney 275A alternator
    XS Power D3100 & Optima yellowtop 55ah
    Orion HCCA 6.5s
    Skar RP-754AB
    Kenwood
  1. Replies: 4
    Last Post: 10-28-2011, 11:25 AM
  2. Capacitor & Second Battery Questions
    By kustomciv in forum Wiring, Electrical and Installation Help
    Last Post: 05-12-2011, 12:00 AM
  3. Second Battery Question.
    By MmatsDude in forum Wiring, Electrical and Installation Help
    Last Post: 08-17-2008, 01:14 PM
  4. mini second battery question, pic*
    By Rsx_03 in forum Wiring, Electrical and Installation Help
    Last Post: 04-15-2007, 11:40 PM
  5. Grounding second battery, questions
    By Supergumby5000 in forum Wiring, Electrical and Installation Help
    Last Post: 01-16-2007, 12:14 PM
