+ Reply to Thread
Results 1 to 8 of 8
Reload Thread: 2013 Challenger install - Remote turn on wire
    OnlyNike's Avatar
    OnlyNike is offline Junior Member
    Feb 2013
    United States
    This weekend i will be helping a friend with an install in his challenger. The battery is in the trunk of the car which make most of the install easy. Just needed some advice about where to put the remote turn on wire. Would i be able to connect the wire to the factory head unit without being able to cut any wires by trimming the end of the wire and putting it into the harness with the current 12v source? our would i have to cut the wire and have to splice them together?
    Worlddre's Avatar
    Worlddre is offline Big Darkie
    Sep 2004
    Charlotte, NC
    28
    17,899
    Re: 2013 Challenger install - Remote turn on wire
    there is no ignition source behind the radio in that vehicle so you are going to either have to grab the pink/white wire at the wireless ignition node or the ignition wire behind the cigarette lighter. Or if you want a heavier gauge source you can look in the passenger kick panel for a 12-14ga dark blue wire.
    "humility in the face of overwhelming genius will obviously amount to hypocrisy"
    OnlyNike's Avatar
    Feb 2013
    United States
    Alright, thank you for the advice!
    eddie_93's Avatar
    eddie_93 is offline Member
    Jul 2012
    Eau Claire, WI
    20
    123
    3 Post(s)
    Quote Originally Posted by OnlyNike View Post
    Just run it to the ignition fuse? Thats what ive always done.
    Kenwood Excelon KDC-X494
    Image Dynamics CTX-6.5cs components on Sony Mobile ES XM-5046
    Sundown SA12 in 2 cubes @ 33hz on Kicker ZX750.1
    Rockford 4 awg/ Big 3 in Scosche 4 awg
    Audio Technix 60 mil deadener on trunk lid, rear deck, and doors
    Bought from: SkarAudio Sold to: VanLan
    MutantDreams's Avatar
    MutantDreams is offline Senior VIP Member
    Apr 2012
    Columbus, Georgia
    198
    2 Post(s)
    I'd recommend running it off the cigarette lighter with a inline fuse.
    NFrazier's Avatar
    NFrazier is offline Senior VIP Member
    Oct 2006
    Massachusetts
    211
    1 Post(s)
    1. cig lighter. 2. in the trunk there's a wire for the cig lighter coming from the fuse box. u can snag it there instead of running it all the wayt up front.
    Nicholas Frazier | MECP Advanced
    iNNovative Concepts
    kramer_212's Avatar
    kramer_212 is offline Music-Expression
    Jul 2011
    Minnesota
    4,282
    23 Post(s)
    i would just solder it in to the ignition, or accessory at the ignition switch.
    NFrazier's Avatar
    Oct 2006
    Massachusetts
    211
    1 Post(s)
    why waste the time when you can grab it right in the trunk with everything else?
    iirc the wire is red/yellow and can switched from constant or ign at the fuse box next to the spare tire.
    That's a picture of the cig socket out of a 2012 Challenger. Same wire is found in the trunk in the wire pack. just test it to make sure, and fuse it (and fuse the ignition wire too if you use that).
    iNNovative Concepts
+ Reply to Thread
  1. no remote turn on wire??? Help ASAP!!, trying to finish the install
    By JarvisB in forum Wiring, Electrical and Installation Help
    Last Post: 03-28-2008, 08:10 PM
  2. help me install my remote turn on wire (not on alpines wire harness)
    By Twistid in forum Wiring, Electrical and Installation Help
    Last Post: 02-19-2006, 09:42 AM
  3. remote turn on wire fuse size
    By btnhfan in forum Wiring, Electrical and Installation Help
    Last Post: 07-16-2004, 10:51 AM
  4. Remote turn on Wire
    By namster44 in forum Amplifiers
    Last Post: 06-26-2003, 09:21 AM
  5. Dead remote turn on wire.
    By jONnyBOi83 in forum Wiring, Electrical and Installation Help
    Last Post: 11-17-2002, 01:44 AM
