Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Reload Thread: Help me understand this battery.
  1. #16
    FamousMassacre's Avatar
    FamousMassacre is offline Team Tantric
    Feb 2013
    San Antonio, Texas
    559
    227 Post(s)
    Re: Help me understand this battery.
    Quote Originally Posted by obxsurfisher View Post
    Everything turned on fine though after you put the nut back on, right?
    Yeah, it just reset everything so I had to change my temp from C to F and reprogram the one touch windows.
    -Team Tantric Sounds-
    -Team Ampere Audio-
    Subs: 4 Tantric MD 15"s - 17sqft 34hz
    Amp: Banda ICE 3500
  2. #17
    Feb 2013
    San Antonio, Texas
    559
    227 Post(s)
    -Team Ampere Audio-
    Amp: Banda ICE 3500
  3. #18
    Feb 2013
    San Antonio, Texas
    559
    227 Post(s)
    I figured everything out.
    The reason the battery was disconnected was because the nut that was taken off caused a loose connection and I can just pull up to disconnect it from the battery.
    The negative on the right just unscrews.
    -Team Ampere Audio-
    Amp: Banda ICE 3500
  4. #19
    Aug 2012
    Salisbury, North Carolina
    92
    31 Post(s)
    Quote Originally Posted by FamousMassacre View Post
    Why would they have the default temp set to celsius? lol
  5. #20
    Feb 2013
    San Antonio, Texas
    559
    227 Post(s)
    The MK3 ford focuses are European versions.
    -Team Ampere Audio-
    Amp: Banda ICE 3500
  6. #21
    Aug 2012
    92
    31 Post(s)
    Ahh ok, well glad you figured it out.
  7. #22
    Feb 2013
    San Antonio, Texas
    559
    227 Post(s)
    How do I disconnect the battery? - Page 2 - Focus Fanatics
    This was a big help too.
    -Team Ampere Audio-
    Amp: Banda ICE 3500
  8. #23
    Timmy13091's Avatar
    Timmy13091 is offline Team DC
    Apr 2012
    Chicago
    2,999
    1 Post(s)
    1286 Post(s)
    When the bolt isn't snug it isn't a good connection .. And that's why it cut off.. The but has to be tight for it to have a good connection .. If I even loosen mine the tiniest bit it goes out ..
  1. Please Help me find this style Battery Terminal
    By snb778 in forum Wiring, Electrical and Installation Help
    Last Post: 03-27-2008, 01:57 AM
  2. Please Help me spec this amp.
    By Wizard9056 in forum Wiring, Electrical and Installation Help
    Last Post: 02-26-2002, 05:18 PM
  3. Can somebody help me with this?
    By Unregistered in forum Amplifiers
    Last Post: 02-18-2002, 04:47 PM
  4. Please help me with this amp!
    By south2001side in forum Wiring, Electrical and Installation Help
    Last Post: 01-12-2002, 10:32 AM
