+ Reply to Thread
Results 1 to 5 of 5
Reload Thread: 2 ohm sub or 4 ohm sub
    billwill1021's Avatar
    billwill1021 is offline Junior Member
    Feb 2013
    Redford, MI
    I'm about to buy a kicker 11dx250.1. 2 ohm rms = 250w, 4 ohm rms = 140w and was wondering if the kicker comp 10 2 ohm sub would be louder than the 4 ohm version. Just want to add a little more kick pedal from rock music. I'm basically a noob when it comes to car audio so any answers are good answers! Thanks in advance!
    momax_powers's Avatar
    momax_powers is online now Senior VIP Member
    Jul 2012
    Canada
    317
    1 Post(s)
    Re: 2 ohm sub or 4 ohm sub
    since the amp does max power at 2 ohms....that would be the way togo....unless you are using a pair of them then you should get two 4ohm woofer to make a 2ohm load
  3. Thanks billwill1021 thanked for this post
  4. #3
    Feb 2013
    Redford, MI
    Just the 1 sub. Had 2 12's before and definatly don't want that bang. My music choice has drastically changed since that system.
  5. #4
    tommydh's Avatar
    tommydh is offline Senior VIP Member
    Mar 2012
    Baltimore, MD
    249
    3 Post(s)
    If running solo sub 2 ohm
  6. #5
    DoesDad's Avatar
    DoesDad is online now CarAudio.com Elite
    Dec 2011
    Tulsa, OK
    1,883
    25 Post(s)
    I'd run 2 of the single 4 ohm 10's and that will get you to a 2 ohm load if you wire them parallel. Throw em' in a ported box and rock out!
+ Reply to Thread
  1. 6" - 7" sub or mid sub in a 1.5 - 2.0 ohm dvc
    By Shipey in forum Subwoofers
    Last Post: 01-24-2013, 09:20 PM
  2. Advantage of little subs or big subs
    By Black-Rob in forum Subwoofers
    Last Post: 12-27-2005, 08:30 AM
  3. Help with speakers, sub or no sub?
    By ToolFan in forum Speakers
    Last Post: 11-03-2005, 01:45 PM
  4. 2 subs or 1 sub?
    By hardrockfan in forum Subwoofers
    Last Post: 08-29-2004, 08:03 PM
  5. car subs or stereo subs
    By infenetwitch in forum Subwoofers
    Last Post: 04-09-2003, 12:48 AM
