+ Reply to Thread
Results 1 to 4 of 4
Reload Thread: Help Brand New Amp wont turn on!
    Nightstrife408's Avatar
    Nightstrife408 is offline Junior Member
    Jan 2013
    USA
    15
    Hey guys I just finished installing my amp + subwoofers. I checked the wiring and im 100% sure i did everything right. Ran 4 gauge power wire from battery to fuse then to another fuse (one fuse from amp install kit and another bigger one from amp i bought itself) then finally to the amp. I even connected the remote wire from the amp to my sony xplod head unit.
    Can anyone help me figure out what is wrong?
    I also have 2 other amps connected to the car but they are for the mid speakers and have no other interference other than using the same remote wire.
    I've tried everything but the amp power led just wont turn on or play any bass.
    Please help thanks!
    momax_powers's Avatar
    momax_powers is offline Senior VIP Member
    Jul 2012
    Canada
    316
    1 Post(s)
    Re: Help Brand New Amp wont turn on!
    check your ground and check your fuses...also check the remote for any breaks in the line....and why do you have 2 fuses on the same power line going to the amp
    also the remote wire may not have enough juice to turn on 3 amps so you may need a relay
    tommydh's Avatar
    tommydh is online now Senior VIP Member
    Mar 2012
    Baltimore, MD
    247
    3 Post(s)
    Try unhooking all the amps from the remote. power each one individually. You may need to use a Relay to power the amps. Your had unit probly cant power three amps they usually are low voltage enough for 1-2 amps
    jdawg's Avatar
    jdawg is offline CarAudio.com Veteran
    Jun 2006
    Maryland, United States
    8,608
    1 Post(s)
    do a quick jump from with a little peice of wire from the power terminal to the remote, if the amp turns on then its a wiring problem, if not its a bad amp or problems in your power or ground to that particular amp
    refs
    woc47, nigro013, defconx3, louisiana_crx, bld 25, supa_c, lancer1978, sxkicker89, 310w6, more, i forget
+ Reply to Thread
  1. Newb Help.. amp wont turn on!!!!!
    By shy6114 in forum Amplifiers
    Last Post: 01-19-2004, 11:20 AM
  2. HELP...Amp wont turn on
    By Miller in forum Amplifiers
    Last Post: 06-20-2003, 04:48 PM
  3. URGENT need help! amp wont turn on?
    By xplicit in forum General Discussion
    Last Post: 05-01-2003, 08:08 PM
  4. URGENT - help plz. amp wont turn on!
    By xplicit in forum Wiring, Electrical and Installation Help
    Last Post: 05-01-2003, 12:26 AM
  5. Help!! Amp Wont Turn On!
    By mr2drift in forum Amplifiers
    Last Post: 02-13-2003, 10:33 PM
