Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 36
Reload Thread: At what point is disconnecting battery negative really not that important?
  1. #16
    Oct 2012
    Southern ILL
    165
    2 Post(s)
    83 Post(s)
    Re: At what point is disconnecting battery negative really not that important?
    If your moving amp power or ground, unhook it first. It doesn't take much of a mistake to ruin your day. Everything else I leave it hooked up. But I've also learned from previous mistakes how to go about that.
    Quote Originally Posted by Jeffdachef View Post
    If your subs seem like they are slow that means you need Time Alignment a feature in sound quality based head units. A good head unit makes the biggest difference because it'll make the subs and speakers match up at the same speed with the time alignment feature.
  2. #17
    ckunke002's Avatar
    ckunke002 is offline Senior VIP Member
    Oct 2011
    Portland, OR
    495
    80 Post(s)
    So is there any difference between disconnecting inline fuse by battery from disconnecting battery neg? Because some people say do both... fuse is a whole lot easier to take out and put back in!
  3. #18
    ewadz3006's Avatar
    ewadz3006 is offline CarAudio.com Elite
    Jan 2012
    erie, PA
    768
    283 Post(s)
    Sort of a thread jack, but i once was out mudding in my truck. Bouncing so hard i broke the crappy battery strap. Batt ends up upside down and welds the bolt for the pos. Cable to the top of my valve cover. That was almost 3 years ago and its still there.
    I feel sorry for those who do not drink, when they wake up on the morning that's the best they're going to feel all day.-Frank Sinatra
    2004 mercury mountaineer
    Hu Kenwood excelon x996
    Fronts Incriminator audio comps
    Front amp Aq 120.4
    sub amp Aq2200d
    subs 2 sundown sa 12's @ 32hz
    wiring knu 1/0 ofc
  4. #19
    ckunke002's Avatar
    Oct 2011
    Portland, OR
    495
    80 Post(s)
    Lolol ^ That's awesome.
    So any answers to the battery neg vs. fuse disconnect question?
  5. #20
    tommydh's Avatar
    tommydh is offline CarAudio.com Elite
    Mar 2012
    Baltimore, MD
    520
    164 Post(s)
    May I suggest using a ground bar with a single 1/0 from battery to the bar? Then all you need to do is un hook at that point and isolate the end from contacting medal Islide my loom over the end then tape up when I need to do this. I had a similar issue but mine was more that the Mini batteries are located near fire wall and did not like being that close to the hood.
  6. #21
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    Quote Originally Posted by ckunke002 View Post
    i always pull al my fuses when moving stuff or installing ..never unhooked my battery unless of course im removing.the battery(s) for some reason
  7. Likes brooklynjoy2008 liked this post
  8. #22
    ckunke002's Avatar
    Oct 2011
    Portland, OR
    495
    80 Post(s)
    Quote Originally Posted by tommydh View Post
    What is a ground bar? Thanks for the suggestion
  9. #23
    tommydh's Avatar
    Mar 2012
    Baltimore, MD
    520
    164 Post(s)
    Disconnecting the ground protects entire electrical system from short circuit eg. airbag discharg accidentally or frying some sensor in more modern vehicle. Removing fus only prevents that circuit from energizing but still potential to short other circuits if screw ran threw or many other f-ups that can happen without thinking.
  10. #24
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    what exactly are u wanting to do that u think u gota unhook the battery neg?
  11. #25
    ckunke002's Avatar
    Oct 2011
    Portland, OR
    495
    80 Post(s)
    Quote Originally Posted by NASTY08IMPALA View Post
    Thanks for the reply. The way I see it, if i'm moving around amps a far better (and easier) way to prevent circuit issues is to pull that inline fuse and maybe for extra measure pull the amp fuses until inline is reinstalled. Does this seem like a good idea?
  12. #26
    tommydh's Avatar
    Mar 2012
    Baltimore, MD
    520
    164 Post(s)
    A ground bar is usualy a piece of copper you can get from electrical supply house that would allo you to run all your grounds to withou connecting to battery. It is similar to a distro block but no fuses.
  13. #27
    ckunke002's Avatar
    Oct 2011
    Portland, OR
    495
    80 Post(s)
    Uninstall amp, reinstall new amp in its place, take out and put in power and ground wires into dist blocks... basically just that stuff
    ---------- Post added at 03:11 AM ---------- Previous post was at 03:11 AM ----------
    If screw ran through? What do you mean by that? I do see what you are saying though
  14. #28
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    yea i just changed out 2 batteries added aluminum buss bars to them and moved amp and few other things and i never unhooked my battery ..im sure theres plenty of stories off people still finding ways to fvck **** up ...i guess if.u wana be extra careful u can unhook it
  15. #29
    ckunke002's Avatar
    Oct 2011
    Portland, OR
    495
    80 Post(s)
    Yeah for this install I might just undo it, but good to know for future reference when I don't really need to do it. Thanks for the advice!
  16. #30
    tommydh's Avatar
    Mar 2012
    Baltimore, MD
    520
    164 Post(s)
    If using a screw to bolt something down or just screw driver slipping and hitting existing wires. Im an electrician by trade I have seen a million different accidents that have occured from accidental stupidity I call it. Drilling through something without checking the other side is a common one. I drive a car that the electrical system is sensitive and shop labor is expensive so I take precautions as much as I can. Ever see a tech take an airbag to the head while working on a dash I have not only does it **** for the poor bastard that got hit but its an expensive screw up. And for all that ay they never have screwed up you either dont do anything or just havent been doing it long enough.
  1. At what point does the battery/alternator need to be upgraded?
    By ckunke002 in forum General Discussion
    Last Post: 12-27-2011, 10:58 AM
  2. At what point is sound deadener necessary?
    By Mills561 in forum General Discussion
    Last Post: 01-24-2011, 07:05 AM
  3. At what point is 1/0 necessary?
    By lovephil in forum Wiring, Electrical and Installation Help
    Last Post: 09-24-2010, 11:51 PM
  4. at what point is this necessary
    By j.clark.90 in forum Wiring, Electrical and Installation Help
    Last Post: 11-21-2009, 04:14 AM
  5. At What Point Can You REALLY Hear the Difference?
    By sungwei in forum General Discussion
    Last Post: 06-02-2004, 01:30 AM
