Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 57 of 57
Reload Thread: My amp going into protect only second start.
  1. #46
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,131
    25 Post(s)
    2108 Post(s)
    Re: My amp going into protect only second start.
    Quote Originally Posted by daveishome View Post
    Yeah, one at a time though haha, just askin cause I know the battery is bad, I drained it allot with my old sub.
    HUH??
  2. #47
    daveishome's Avatar
    daveishome is offline Member
    Oct 2012
    Canada
    111
    48 Post(s)
    Quote Originally Posted by audiobaun View Post
    HUH??
    Yeah it was my first sub, re sxx I played it when the car was off allot.
    Could that make the amp go into protect?
    gotta take the batt into a shop.
  3. #48
    audiobaun's Avatar
    Jun 2011
    Tx
    9,131
    25 Post(s)
    2108 Post(s)
    Be a REAL GOOD POSSIBILITY man
  4. Thanks daveishome thanked for this post
    Likes daveishome liked this post
  5. #49
    amp_man's Avatar
    amp_man is offline Junior Member
    Dec 2010
    Pasco,Florida
    1 Post(s)
    That's your pproblem. When you first start the car your battery voltage is low in the morning from sitting all high and if you have any accessories installed that will drain a little power through the night. Once you run your car for the first time the amp is getting the right voltage hence its working then you shut it off and start it again it goes into protect. Although your alternator putting out 16 volts it should shut the amp down after a little while of use but it the alternator is probably putting out that 16 volts at different times. Once running and the amp is getting 16 volts it will stay on. Each amp is different in its protection circuit when it should'nt. I have repaired many JL amps as my business was an authorized dealer for JL and repair. I have seen and fixed this problem before. I still have a small business repairing amps for a living as well as sell and installing car audio. I'm MECP certified plus I'm an electronics engineer and have designed 2 mono sub amps that sold very well. I am the cheapest amp repair in the USA and offer allot of services that no one else does. I also offer video conferencing to help people learn and show them how to test some components to basicly find out if a person has a power supply problem or shorted outputs. I also do the same by phone. I am currently in the middle of making a DVD to teach people to repair car amps. There are two sections, one is for the person who wants to jump right in before learning any basic and extend end electronics but on that I do teach a small amount of basic electronics cause it helps to understand easier but its and in laymen terms plus I cover the tools needed which for the jump right in part is basicly a volt meter and a type of power supply. The other section is an all out learning process and is designed very well for anyone to learn. There's allot of videos and pics and animations. Been working on this for 4 years. Also I put a list in of over 30 amp manufacturers and most if not all their amps that I list the most common problems that occur and what and how to repair that amp. I invite anyone who needs help to contact me. Just send me a message and I'll send you my info. As I said, I try to get a person who is having a problem to diagnose his or her amp first with my help before sending it out for repair to whatever business they choose. I am very good at what I do and get most of my online business through forums like this one. For instance, fixya.com, diycaraudio.com and many more as well as local advertising. Sorry this is so long but I'm letting people know I'm back open for business. I wasn't repairing for about 8 months. I had to take care of my mother who is still sick. Well thank you for reaching this if you did and I hope I will be able to assist anyone needing help. Have a great year to all.
  6. #50
    daveishome's Avatar
    Oct 2012
    Canada
    111
    48 Post(s)
    Quote Originally Posted by amp_man View Post
    No the voltmeter was bad and it was not running at 16v, I swapped the battery with another good one and it did the same thing, is it the alt then?
  7. #51
    Apollo220's Avatar
    Apollo220 is offline CarAudio.com Elite
    Jul 2009
    Columbus, GA
    1,739
    97 Post(s)
    it could be the amp has a short in it ... what you should do is run the car and see it holds a charge if the alternator is bad the car won't charge . kinda leading me to believe the amp has some sort of short . probably in the power rail
    08 Impala REbuild in my New car in process
    Kenwood Exceleon x994 ,Dynamat Xtreme in da trunk
    Mechman 270 amp alternator
    _________________________
    Feedback LInk here http://www.caraudio.com/forum/showthread.php?p=6400261#post6400261
    Bought from:basscourt2009,fasfocus00,fasfocus00
    Sold to: ALter ego trip , Bhhong , Jeeper07 , 09Alti , apbt55 , akheathen , Todj , Corey0195 , OracleM19
  8. #52
    Apollo220's Avatar
    Jul 2009
    Columbus, GA
    1,739
    97 Post(s)
    also it not a very good idea to run your system with the car not running for a long period of time .
  9. #53
    daveishome's Avatar
    Oct 2012
    Canada
    111
    48 Post(s)
    Quote Originally Posted by Apollo220 View Post
    Yeah it does seem like it's the amp, weird because It works after sitting for a day.
  10. #54
    Apollo220's Avatar
    Jul 2009
    Columbus, GA
    1,739
    97 Post(s)
    yeah electronics are funny the slightest strain on them can reek havoc
  11. #55
    JoeK's Avatar
    JoeK is offline CarAudio.com Elite
    Apr 2012
    Ringtown, PA
    23
    1,055
    412 Post(s)
    Disconnect the speakers, play some songs... see what it does.
    If its always in protect, unplug rcas and speakers, then unplug rcas and connect the speakers
    2003 Jeep Liberty Sport
    2x DC Audio XL 12
    2x SK-1500.1s strapped
    Tenney 275A alternator
    XS Power D3100 & Optima yellowtop 55ah
    Orion HCCA 6.5s
    Skar RP-754AB
    Kenwood
  12. #56
    daveishome's Avatar
    Oct 2012
    Canada
    111
    48 Post(s)
    So turns out that the amp was broken lol, I get all store credit back from sonicelectronics.com
    What should the next amp be? any suggestions?
  13. #57
    dbertoli's Avatar
    dbertoli is offline Member
    Apr 2013
    London ontario
    42
    3 Post(s)
    Just a thought, open up your amp it had likely been overheated one too many times. Chances are you will see effects of the heat, like rubber warped or liquids on the acid board. Find and if capable, test ever resistor, cap, and chip on the board. You can get replacements off ebay easily and solder the new ones on. Also check to make sure your heat sink is secured properly, you may want to install/fabricate a larger heat sink or possibly different sized fins. Or maybe add a fan. A repair can be pretty simple and cheap with basic soldering know how. But mot always guaranteed it will fix the problem.
  1. Why is my amp going into PROTECT
    By SLIPKANOT in forum Wiring, Electrical and Installation Help
    Last Post: 10-25-2012, 11:14 PM
  2. Is my amp going into protect? WHY would it do this?
    By Weeznur32 in forum Amplifiers
    Last Post: 06-02-2012, 04:57 AM
  3. Why does my amp go into protection?
    By 86vette07 in forum Amplifiers
    Last Post: 07-02-2009, 01:22 AM
  4. amp goes into protection when car starts
    By BulldogSr04 in forum Wiring, Electrical and Installation Help
    Last Post: 12-08-2003, 09:13 PM
  5. sub amp going into protection when low notes hit
    By B|2imstone in forum Amplifiers
    Last Post: 12-08-2003, 04:12 AM
