What type of fuse is it? ANL, Mini ANL? If it's AGU (Glass fuse) you may definitely have a voltage problem.
Deck Kenwood KDC-X595 (For now)
Mid/High Speakers Infinity 6x8 Coaxial's and RF P1 Tweeters in front doors
Mid/High Amp Orion 280GX 2x80wrms (Old school)
Sub Rockford Fosgate T1D412 12" 800wrms
Sub Box 2.5 Cubic foot, high output, slot ported
Sub Amp JL Audio 1000/1 v1, 1000wrms @ 11-14.5 volts
You should test the voltage at the battery and the amp. Also check the remote wire voltage.
That amp will not run at 16 volts. And that is odd if your batteries and alternator aren't 16 volt.
08 Impala REbuild in my New car in process
Kenwood Exceleon x994 ,Dynamat Xtreme in da trunk
Mechman 270 amp alternator
_________________________
Feedback LInk here http://www.caraudio.com/forum/showthread.php?p=6400261#post6400261
Bought from:basscourt2009,fasfocus00,fasfocus00
Sold to: ALter ego trip , Bhhong , Jeeper07 , 09Alti , apbt55 , akheathen , Todj , Corey0195 , OracleM19
i can't remember where the page is but the amp needs to be tuned and you can do it with a voltage meter I'm sure someone can post the link here
wow i missed the 16 volts . He is pretty lucky that the brain if the car has one hasn't burnt out . that will cost your left nut to fix . OP i would suggest unhooking the alternator and getting it checked out . OR taking the car to auto zone or Advanced Auto and having them do a battery alternator test . they can tell you whats wrong with your alternator if anything is wrong for free
OP, what kind of car is it?
Bookmarks
