2 way fuse block question
I am currently in the process of hooking up a second amp. I got the knucpnceptz dual amp instalation kit. Its a 0 gauge to block & then 2 4 gauge to both amps. Do I need a second distrobution block for grounds, or can I just run 2 seperate grounds from amp like normal?
Re: 2 way fuse block question
Don't necessarily need a dist block for grounds, you can run separates from amps to a common point.
agreed, no need for a second block. be sure to bolt the grounds to the thickest metal you can find (floor). also upgrade battery to chassis and engine block to chassis grounds.
