Results 1 to 3 of 3
Reload Thread: 2008 G6 Steering Wheel Control wiring
    Manuelxr7's Avatar
    Manuelxr7 is offline Junior Member
    Jan 2013
    Turlock, CA
    Hi! new here so Not sure if this is the right section, I have a 2008 G6 GXP, and I installed a 2010 G6 steering wheel so I could use the DIC buttons on the 2010 wheel with my 2010 Gauge cluster I installed. Everything works on the wheel except for the "Info" and "Enter" buttons. I have attatched diagrams of my 2008, and of a 2010. It looks like I need to add a wire/relay where it says "Instrument cluster 1358 D-GN/WH" on the 2010 diagram. I am not very good with this stuff, so even if someone can just tell me what needs to be done I could take my car to an installer to have it done. (I also have had my BCM programmed to 2010 specs)2008 G6 Steering Wheel Control wiring-image.jpg2008 G6 Steering Wheel Control wiring-image.jpg
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Re: 2008 G6 Steering Wheel Control wiring
    where are the original info and enter buttons for a 2008 wired to? if a 2008 didn't have either of those inputs, then neither does the 2008 computer. adding programming doesn't add inputs. a relay won't work. the 2010 looks for specific resistances to determine what button was pressed.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
    Manuelxr7's Avatar
    Jan 2013
    Turlock, CA
    The 2008 doesn't have those buttons on the steering wheel, it has them on the radio. My computer is fully setup for it to work. WAMS did it. I was told that I need to "add a green/white tracer wire from pin 1, circuit 1358 to IPC cavity B3" and that's all they told me, to me that is in a different language lol.
  1. Steering wheel controls after harness installed...
    By thinkbrianthink in forum Wiring, Electrical and Installation Help
    Last Post: 02-14-2004, 10:12 PM
  2. steering wheel controls
    By fishinman14 in forum General Discussion
    Last Post: 01-18-2004, 10:28 PM
  3. alpine 9815 and steering wheel controls
    By orlmailman in forum General Discussion
    Last Post: 07-20-2003, 01:21 PM
  4. Trans Am Steering Wheel Controls
    By TheHeadFL in forum General Discussion
    Last Post: 04-05-2002, 07:24 PM
