+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: how to determine inline fuse rating
  1. #16
    mat3833's Avatar
    mat3833 is offline CarAudio.com Elite
    Mar 2008
    florida
    774
    1 Post(s)
    Re: how to determine inline fuse rating
    decided on 4 total. 1 for the alt to bat, 1 for bat to distro, and 1 for each amp. going to fuse each amp at their fuse rating, fuse the bat to distro @ 250, and fuse the alt to bat @300.
    anyone have a good place to buy 2 weatherproof 0ga inline fuse holders that come with fuses and 2 inline 4 ga fuse holders that come with fuses?
    Matt
    Star Mountain Nuthugger #5
    2 SPLaudio 8's in a Star mountain 1.26 cubes @32hz
    Kicker ZX-750 @4 ohms(possibly going to 1 ohm if im feeling ballsy)
    Quote Originally Posted by double 07 View Post
    Sub cutout got a little skar on it...dad blamed round over bit bearing came flying off.......LOL.......
    Quote Originally Posted by gckless View Post
    A little Skar on it? Was it a B-stock bit?
    Refs:
    bought from Nitefury360, Tallic, SPLaudio X2
    Traded with Marleyskater420
  2. #17
    jnewnam88's Avatar
    jnewnam88 is offline Member
    Jan 2013
    Jacksonville, FL
    58
    Quote Originally Posted by mat3833 View Post
    Matt
    So you are going to run 0 ga wiring from the distro blocks to the amp with a 50 amp fuse???
    2011 Impala LTZ w/ Bose
    **Prospective system**
    Pioneer AVH-P8400BH
    2 Custom Sundown Audio Zv3 in Custom Ported Enclosure
    AQ3500D.1, AQ120.4
    CDT HD-61A, CDT 6.5 for the rear
    Big Three upgrade and all wiring from Audio Technix
    XS Power D3100, XS Power D3400, Mechman 240A Billet Alt
  3. #18
    mat3833's Avatar
    Mar 2008
    florida
    774
    1 Post(s)
    im running 4ga from the distro to the amps and i figured someone would tell me to fuse for the 250-300 amps the wire is rated for. lol
    Matt
    Refs:
  4. #19
    mat3833's Avatar
    Mar 2008
    florida
    774
    1 Post(s)
    so i should fuse the 0ga at 300 and the 4ga at 250 amps instead of dropping the value down to what the amps are fused for?
    Matt
    Refs:
+ Reply to Thread
  1. how to determine best box size?
    By SSS 18734 in forum Enclosure Design & Construction Help
    Last Post: 09-06-2005, 03:21 PM
  2. how to determine watts going to sub???
    By DMarsh525 in forum Amplifiers
    Last Post: 08-13-2005, 02:01 AM
  3. how to determine the correct port area??
    By RCwhat in forum Enclosure Design & Construction Help
    Last Post: 04-24-2005, 06:49 PM
  4. How to determine the right size Alt?
    By cjj2d in forum Wiring, Electrical and Installation Help
    Last Post: 04-12-2005, 04:29 PM
  5. How to determine if a sub is in good shape?
    By shatter187 in forum General Discussion
    Last Post: 06-25-2004, 08:43 PM
