Results 1 to 7 of 7
Reload Thread: 2004 stratus big 3?
    Xjeff's Avatar
    Xjeff is offline Member
    Nov 2012
    The dalles
    97
    20 Post(s)
    2004 stratus big 3?
    Ok so I was doing the big 3 on a buddies 2004 dodge stratus and I noticed the stock wires only has the batt + to alt + and then batt - to frame. But no batt - to engine block, there's a wire from the frame that the batt - connects to that leads to the engine block. So should I just add the big 3 wire from the frame to the block, or run the big 3 from batt - to the same block ground? Well for now we did a big 2 upgrade lol, but plan in doing something tomorrow with it, cus it still didn't fix the lights dimming.
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    Re: 2004 stratus big 3?
    U wana ground to alt case ..power to alt and ground to frame
    Xjeff's Avatar
    Nov 2012
    The dalles
    97
    20 Post(s)
    So the battery - to the alt - ?
    Tenacious's Avatar
    Tenacious is offline Banned
    May 2012
    Lebanon, TN
    542
    239 Post(s)
    Most alternators don't have a negative... The case itself is the ground for the alternator and it is ground through the engine block which usually has a tiny wire run to a chassis ground. Do a run of wire between a chassis ground and the engine block or the alternator case, either will work.
    Tenacious's Avatar
    May 2012
    Lebanon, TN
    542
    239 Post(s)
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    Yes ground the alt from batt to the case of the alt ..one of its mounting bolts
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    Tenacious's Avatar
    May 2012
    Lebanon, TN
    542
    239 Post(s)
    Also a commonly overlooked detail... Sand ALL paint off of ground points. You might as well have stock wiring if your grounds have paint all over them.
  1. Big 3 on Chrysler Sebring/Dodge Stratus
    By JeffM in forum Wiring, Electrical and Installation Help
    Last Post: 01-28-2008, 12:48 AM
  2. 2004 Jeep Liberty Big 3 Done w/ Pics!
    By Kriszilla in forum Wiring, Electrical and Installation Help
    Last Post: 12-05-2007, 01:45 AM
  3. Unlock/Lock help in 2004 Dodge Stratus
    By maldecido33 in forum Car Video, Security and Electronics
    Last Post: 03-05-2007, 08:28 PM
  4. Anyone do the big 3 on a 2004 civic and have pics?
    By e22s in forum Wiring, Electrical and Installation Help
    Last Post: 04-23-2006, 04:53 PM
  5. Big issues - 2004 Mercury Sable LS Premium
    By wingnut691983 in forum Wiring, Electrical and Installation Help
    Last Post: 06-10-2005, 03:06 PM
