Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Reload Thread: Cranky Type-X HELP!
  1. #16
    Jul 2006
    Georgia
    12,847
    1 Post(s)
    1170 Post(s)
    Re: Cranky Type-X HELP!
    Quote Originally Posted by TahoeTunes3000 View Post
    It gets hot sometimes but it doesnt usually matter if its hot or not. It will randomly not work or cut out when ive been playing it at a low volume or even not playing at all 0 volume and i will hear the thump of it cutting out.
    clean the grease off your ground and re try
    REFS:
    Squeak9798, Kumbos310w6, BigBangTheory, Jmanpc, MillzThaYungin, WLDock, -Leister-, ThomasG, J31Rob (and a few more I have forgotten)
    Quote Originally Posted by BassAndBeer View Post
    sorry man but ford will always be a ford. ford is the sony xplod of cars and trucks. you had bad experiences with chevy because your a ford guy. its what seperates the men from the boys. friend billy use to drive a ford. he drives a chevy now. they call him billy no more. hes known as bill now..
  2. #17
    ace_800's Avatar
    ace_800 is offline CarAudio.com Veteran
    May 2004
    Okinawa, Japan
    37
    5,421
    4 Post(s)
    503 Post(s)
    ok so i ohmed it out at the box and i got 2.2 I have the amp settings at 30 hz and 0.1-10v.
    According to the manual you should have the gain selector to 1.0-8.0v, your headunit should be at least 2v. I would turn the subsonic filter to off as well, the dial should be at 80hz. Is the light on the amp red or blue?
    Current set up: 94 Toyota Chaser (1JZ motor) Kenwood 5907, 3 way active (Alpine DLX-Z30T Tweets, CDT 04's and 06's), Helix P Six DSP/Amp, 4 IDQ12's, MMATS D3000.1
    66 Pontiac GTO, modified stock radio, Crossfire CFA 302, Kicker KS6.2's in the front kicks, Crossfire CFA 452 for the 6x9's I need.
  3. #18
    TahoeTunes3000's Avatar
    TahoeTunes3000 is offline Junior Member
    Jan 2013
    Minneapolis, MN
    8 Post(s)
    Quote Originally Posted by ace_800 View Post
    Its blue I have never seen a red light on. Im guessing that means protect mode? I will switch it and see what happens. I dont know where the head unit voltage would be from tho.
  4. #19
    ace_800's Avatar
    May 2004
    Okinawa, Japan
    37
    5,421
    4 Post(s)
    503 Post(s)
    It does, or low/high voltage. Head unit voltage comes from your alpine. That Alpines output voltage is 4v so you should be set at the 1.0- 8v setting. If your voltage was less than 1 then the other setting.
  5. #20
    Jan 2013
    Minneapolis, MN
    8 Post(s)
    I might have just found the problem when checking the grounds. My rca wires run by where i have my grounds under the carpet panel. It looks like a screw might have cut open the insulation and corroded the wire. But whats weird is I tried a new set of those just in case that was it. I waited for it to happen and then I plugged the new cables in and it still wasnt working but maybe thats cuz i never gave it a chance to reset.
  6. #21
    CaptM's Avatar
    CaptM is offline Senior VIP Member
    Feb 2012
    WA
    186
    64 Post(s)
    Try running rcas out in the open above carpet just to test, and check voltage of rcas. If possible take a picture of your amp settings and the pros on here will tell you a rough estimate on where to set things. EASIEST way google how to set your amp find a good guide and go from there.
  7. #22
    Oct 2012
    Whitecourt, Alberta
    41
    16 Post(s)
    pdx 1-1000 is at 2 or 4 ohm.... both 1000 watts rms
  8. #23
    NoKings's Avatar
    NoKings is offline Member
    Mar 2012
    Nebraska
    63
    13 Post(s)
    Quote Originally Posted by tahoetunes3000 View Post
    i got the amp set to 0 ohms and the sub im not sure but i got the little bridge plates in to both coils if thats what your talking about.
    Infinite power! It was so simple!
  9. Thanks garretttt4 thanked for this post
    Likes joeu3 liked this post
  1. maaaaaaaajor type r help
    By rickcd in forum Subwoofers
    Last Post: 03-08-2006, 07:57 PM
  2. Need Alpine Type R Help
    By shortys1023 in forum General Discussion
    Last Post: 11-13-2005, 02:27 AM
  3. type r help...
    By ipseity in forum Wiring, Electrical and Installation Help
    Last Post: 11-10-2005, 07:59 PM
  4. Trapezoid Type Enclosure (HELP)
    By Slammed in forum Enclosure Design & Construction Help
    Last Post: 09-13-2005, 10:13 AM
