Only when I start my truck up there is a distorted static pop through my tweeters if the volume on my radio is higher than a 1/4 up..other than that it sounds amazing
Ran the new remote...still has a pop once it comes on after I turn my truck on...guess its the new amp?
check your grounds? go through everything again and make sure that where your ground is for your amp is in a suitable place, NOT grounded to some metal that is paper thin. make sure you ground to somehtig that is decently think and where its grounded at make sure you use sand paper and sand the crap out of the spot so its BARE metal. maybe pull your head unit out of your dash and make sure that when you spliced your wires together to the harness that theres no bare wires touching each other, wire caps and or electrical tape work good. also make sure your rca wires are not running on the same side as your power wire i rn power on one side of my car and rcas on the passanger side. that can cause static and unwanted noises.
Run a ground from your battery to the distro box... make sure you do the big 3 also when you do this...
2007 Chevy Impala LT
HU: Clarion CZ500 Front Speakers: CDT HD6.1
Sub: 12" Hispl Custom Shocker Extreme Box: 1.9 cubes net tuned to 32hz Amp: Sub: EarthQuake 2k @2ohm / Front Stage: Zapco 350
Sold To: Spooney x1 , Bgfx x1, garychoffmann x1 Bought From: ssteele18 x 1 , Louisiana_CRX x1 , mylows x3 , Spooney x4 , Bettr n' Revrse x1 , draginx x1 , CerwinVega_Fan x1 , infamous_e46 x2 , mclerico83 x1 , argent_audio x1 , Whitedragon551 x1 , Vertex Audio x3, Buck "box designs" x2 , RAM_Designs "box design" Traded With: infamous_e46 x1 , Spooney x4 "repair of amp x2"
Bookmarks
