+ Reply to Thread
Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 16 to 30 of 88
Reload Thread: Subs just don't seem loud enough
  1. #16
    Falcons's Avatar
    Falcons is offline that **** i dont like
    Jan 2011
    Albion, New York, United States
    5,087
    18 Post(s)
    Re: Subs just don't seem loud enough
    Quote Originally Posted by grobbins81 View Post
    Okay. Could a bad ground cause a wattage drop in the system? It's just not making any sense to me that my friends l7 12s can be heard from down the road and my two 15s sound like some cheap 10s just enough bass to over ride door speakers.
    absolutely. what are you grounded to? that was my issue with my system at first.
    Things to look forward to:
    (2) 10" or 12" imperium audio designs subs
    set of PHD MF 6.5" comps
    Completely seal off and deaden my doors
    aquire a 2k amp
    aquire a 2 channel amp for front stage
  2. #17
    grobbins81's Avatar
    grobbins81 is offline Junior Member
    Mar 2012
    ellenboro
    17
    I have the amp grounded to an existing seat bolt and I sanded off As much paint as I could. This was the only easily accessible thing to put the ring terminal onto.
  3. #18
    Falcons's Avatar
    Jan 2011
    5,087
    18 Post(s)
    seat bolts are one of the worst places you can ground. i can almost guarentee thats one of your problems.
    aquire a 2k amp
  4. #19
    argenis69's Avatar
    argenis69 is offline Member
    Dec 2012
    NY, USA
    77
    Grobbins, are you talking about my setup, lol, BC I'm having the same exact issues and practically the same scenario.
  5. #20
    grobbins81's Avatar
    Mar 2012
    ellenboro
    17
    I can't find anywhere else to ground to. What do you reccomend I do for a ground. I've considered that was my problem from the start but the fact they were merely working made me push it aside until now.
  6. #21
    UnderFire's Avatar
    UnderFire is offline CarAudio.com Elite
    Apr 2011
    Dayton, OR, 97114
    1,750
    26 Post(s)
    That's a lot of amp to be grounded anywhere but directly to the frame. Seat bolts in newer cars are usually oddly shaped and make horrible grounding points. Definitely change the ground and see if that helps.
    97 4runner, 3RZ, 5 Speed
    Headunit: Pioneer DEH-P9800BT
    Mids: Lanzar 6m
    Tweets: Crescendo CCX
    Fronts Amp: Alpine PDX4.100
    Sub Amp:Hifonics BRZ1.1700D
    Substage: 18" SSA ZCON
    Electrical: 160 Amp Alt, Duralast Gold, C&D270FR, 2/0 Throughout
  7. #22
    grobbins81's Avatar
    Mar 2012
    ellenboro
    17
    Quote Originally Posted by argenis69 View Post
    Haha glad Im not the only one. This is so aggravating. I've got too much money in this for it not be loud.
  8. #23
    Falcons's Avatar
    Jan 2011
    5,087
    18 Post(s)
    ground to the actual frame of the car, or spend the extra money to do one long ground connecting straight to your battery.
    aquire a 2k amp
  9. #24
    grobbins81's Avatar
    Mar 2012
    ellenboro
    17
    how would I go about grounding straight to the frame? Run the ground out of the cab onto the frame? what kind of screw or an actual bolt? can the ground get wet ? lots of questions I know but I want to be sure. Still learning here lol
  10. #25
    Falcons's Avatar
    Jan 2011
    5,087
    18 Post(s)
    nah keep it dry. and you should use a bolt and nut. you just gotta get creative and make your own ground :P
    aquire a 2k amp
  11. #26
    argenis69's Avatar
    Dec 2012
    NY, USA
    77
    Yes, I'm so disappointed, just like you, I used to have an L7 15" and sounded way louder than now after spending almost 2k upgrading my stuff.
  12. #27
    Falcons's Avatar
    Jan 2011
    5,087
    18 Post(s)
    yeah guys try relocating your grounds. sand to bare metal, make sure they are tight.
    aquire a 2k amp
  13. #28
    jungstah's Avatar
    jungstah is offline Senior VIP Member
    May 2012
    san francisco
    278
    2 Post(s)
    2 grand? what'd you buy?
    Pioneer AVH-P2400BT
    Stock Pioneer 4" components
    Hifonics Brutus BRZ1700.1D
    Two SA-12's
    cruddy prefab ported box----new box otw
  14. #29
    mylows10's Avatar
    mylows10 is online now WEST COAST DC & PHD REP mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    13,634
    381 Post(s)
    also check and make sure your subs aren't out of phase ,been seeing that alot around here lately as well,also you said you box is 6.5 ^3 ,is that before port and sub displacement or after that also may be an issue .
    pioneer avhp 4100 dvd, 2 dc lvl 4 10's custom built by Thor's hammer , ab vfl 4480
    ab vfl 150.4 ,2 pc 2150 ,
    cdt 6.5 es 61 im mids,cdt es 010 tweets with es 200 us x overs stinger hpm o gauge wires
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  15. #30
    argenis69's Avatar
    Dec 2012
    NY, USA
    77
    Fi SP4, crescendo amp, custom enclosure, hu, new wiring, etc... My Christmas gift to myself and not yet happy about it. Guys, if you can please help me out on my "Box hz tuning" thread also, I'm looking for every possible solution to my sub problem, I really appreciate it.
+ Reply to Thread
  1. Subs just don't sound "right"
    By clysports in forum Wiring, Electrical and Installation Help
    Last Post: 02-16-2012, 10:01 PM
  2. Speakers don't sound loud enough
    By Leenix in forum General Discussion
    Last Post: 09-13-2011, 07:44 PM
  3. HELP dont think subs are loud enough
    By enns_aw in forum Subwoofers
    Last Post: 01-21-2007, 01:18 PM
  4. my sub just anit loud
    By hotbodkev in forum Wiring, Electrical and Installation Help
    Last Post: 04-23-2006, 12:22 PM
  5. subs dont seem loud as it use to
    By turnstylez18 in forum General Discussion
    Last Post: 11-27-2005, 01:33 PM
Tags for this Thread
