+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Reload Thread: Voltage Problems, Please Help!!!
  1. #16
    rlambert02's Avatar
    rlambert02 is offline Member
    Jun 2011
    PHX, AZ
    35
    Re: Voltage Problems, Please Help!!!
    I checked today and it was at 14.1-14.4 at idle. And i was running the amp at 1ohm tuned conservatiley
    ---------- Post added at 05:42 PM ---------- Previous post was at 05:42 PM ----------
    I checked today and it was at 14.1-14.4 at idle. And i was running the amp at 1ohm tuned conservatively
  2. #17
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,504
    24 Post(s)
    Quote Originally Posted by rlambert02 View Post
    Was that under load? Where was this checked? That's what you should be seeing though.
    Quote Originally Posted by ducatipaso View Post
    To say that 8inch, 10inch and even 12inch subs are for girls is just not true. 15inch subs can't play fast beats, they take more power and that taxes the vehicles electrical system. You will wake up and "hear" then see the light at the end of the tunnel and it will be 3 10's pounding so hard you wont even open your trunk or turn your system on because you 15's will sound sloppy & weak.
    Quote Originally Posted by benbenondatrack View Post
    stfu lesbo.why are you worried about me so much? you must want to date me ya little cookie monster but i dont even like sweets. your just a cup full of ice, dirt dead nasty azz ice...without the water.
  3. #18
    rlambert02's Avatar
    Jun 2011
    PHX, AZ
    35
    no that was with nothing hooked up
+ Reply to Thread
  1. voltage problem...please help
    By aaron7114 in forum Wiring, Electrical and Installation Help
    Last Post: 08-12-2007, 03:08 AM
  2. alpine type r speaker PROBLEM-Please help
    By saltyjesus in forum Subwoofers
    Last Post: 10-07-2002, 10:44 AM
  3. head unit problems, please help
    By SuckMikeHawk23 in forum General Discussion
    Last Post: 07-01-2002, 07:57 PM
  4. Celica Headunit Problem-PLEASE HELP!
    By phatt_boy in forum General Discussion
    Last Post: 04-19-2002, 03:53 PM
  5. speaker problems please help
    By millinivation in forum Subwoofers
    Last Post: 04-10-2002, 10:28 PM
Tags for this Thread
