Ok here is the issue that I am running into. With the current setup that I have my mono amps will go into protect mode then turn right back on but only to a select few songs and only if turned up at high volumes. I have read that the Infinity KappaOne Amps have a under voltage protection which is the only thing I can think of that would cause the mono block amps to cut out then come back on right away. I know that the two mono block amps each have a 160 amps of fusing and the 4 channel has 120 amps of fusing. As of right now my alternator is still stock and I need to still do the big three upgrade. I do plan on running a battery isolator and adding another kinetik HC1400 to the mix or should I move the HC1400 to the front and go bigger on the rear?
2012 Pioneer AVH-P4400BH 7" indash DVD player.
2012 2x Tview T120PL 12.2" headrest monitors
2012 1x Tview T156IR 15.4" Flip down Monitor
2012 2x Tview T102SV 10.2 Sunvisor Monitors
2012 Infinity Kappa Perfect 6.1 6.5 Components
2012 Infinity Kappa 693.9i 6x9
2012 2x Infinity KappaOne 1,600w Mono block amps
2012 1x Infinity KappaFour 1,200w 4 Channel amp
2012 2x Kicker 12" CVX 2 Ohm Subs (subs are wired at a 2 ohm load, one sub to each mono block)
1x custom built 3 cubic square per chamber vented enclosure
2012 1x Kenetik HC1400 Battery
0 gauge wire from the battery to the kenetik and 4 gauge to the amps.
Register To Reply
Bookmarks
