Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: sub turns off?
  1. #16
    TaylorFade's Avatar
    TaylorFade is offline I fail.
    Dec 2009
    Baton Rouge, La.
    3,019
    19 Post(s)
    1292 Post(s)
    Re: sub turns off?
    Quote Originally Posted by BrownVanMan View Post
    My guess is that the amp is going into protect because of improper settings(low voltage) or improper impedence(to low).
    This
    Quote Originally Posted by eCrack View Post
    TaylorFail
    Quote Originally Posted by Suicide Bobb View Post
    Taylorfail, v.2
    Quote Originally Posted by Imtjnotu View Post
    tailorFail v.3
    Quote Originally Posted by brodeisel View Post
    TaylorFail v.4
    Quote Originally Posted by tat2bass View Post
    TaylorWin v.1?
  2. #17
    frogcase2002's Avatar
    frogcase2002 is offline CarAudio.com Elite
    Dec 2011
    hamilton, ohio
    623
    1 Post(s)
    132 Post(s)
    Re: sub turns off?
    Quote Originally Posted by Camarillo View Post
    It was one positive to other pos and one negative to other neg and then so each pos and neg to amp.
    I was thinking it went into protective mode too..but don't amps only go into protective mode when they overheat?
    Well problem solved. That amp takes 4 ohm and your wiring it to 1. An amp doesn't have to over heat or shut off if there is to low of an ohm. It can just not really play
    Hook a positive from one side of the sub to the negative on the other side and then the positive and negative that are left hook to the amp..........so a neg from one side of the sub and a pos from the other side and connect the other neg and pos together with a short wire. And you will be good
  3. #18
    Camarillo's Avatar
    Camarillo is offline Member
    Nov 2012
    south florida
    56
    15 Post(s)
    Re: sub turns off?
    I will give it a go!
  4. #19
    Dec 2011
    hamilton, ohio
    623
    1 Post(s)
    132 Post(s)
    Re: sub turns off?
    Cool. Let me know what happens
  1. System sounds better with sub turned off
    By jcmuse in forum Subwoofers
    Last Post: 06-02-2012, 12:47 PM
  2. Need help sub turns off
    By Webman33569 in forum Wiring, Electrical and Installation Help
    Last Post: 02-21-2009, 12:22 AM
  3. Replies: 1
    Last Post: 12-10-2008, 05:31 AM
  4. Subs turning off
    By N252005 in forum Wiring, Electrical and Installation Help
    Last Post: 06-20-2005, 08:50 AM
  5. Turning off Subs
    By paul83085 in forum Subwoofers
    Last Post: 06-13-2003, 03:04 PM
