Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 50
Reload Thread: two 4ks
  1. #16
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    Re: two 4ks
    4 rolls 200 ft .
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  2. #17
    garretttt4's Avatar
    garretttt4 is offline big pimpin
    Aug 2012
    Watertown sd
    2,456
    1 Post(s)
    1027 Post(s)
    Re: two 4ks
    Quote Originally Posted by gckless View Post
    I do agree with the dual alts though.
    I think dual alts is a very good idea. You can draw more than 300A with a single 4k theoretically. What's the fuse rating on your amp? But I would do 3-4 runs of both positive and negative depending on what size alts you get (if you go dual alt, which again should probably be done.), skip the grounding to frame. It depends on how you will play it too. If it's going to be cranked daily, definitely get a pair of alts. If it's only going to be cranked during comps or only sometimes for shorter durations, you should be ok with the biggest single alt you can find. And in that case, like I said before, you should be ok with 2 pos, 2 neg runs.
    You have to look at where you will actually be drawing all your power from. Up front you only have your alt (single alt in this example), which you know exactly how much amperage it will kick out, and a single battery. So, from front to back, you have no more than 2 runs of 1/0ga CCA or OFC can carry traveling along that wire. In back, at the battery bank, is where your large draw potential is, because you have the amperage from the front (alt and batt) and all batts in back added together. That's where you really want some electrical beef.
    i couldnt find any fusing ratings on the amp but soemone told me like 300-350 amps
    01 Silverado 2500hd
    Four custom mmats juggernaut 12's. (For sale, or trade for two beefy 12's or 15's)
    Bought from: Jayzbent, mylows10, logan527, Timmy13091, wingsfreak9, Underfire
    Traded with: mylows10(x2), knowmadic
    Sold to: 03silverado03, foomanchu, heel4lyfe, Timmy13091, wErd
  3. #18
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Re: two 4ks
    Quote Originally Posted by mylows10 View Post
    you said you wanted to be loud ,i'm telling you this from experience run 2 power wires off of each alt and all the grounds from the fron battery to the rear batteries.you can cut the grounds down abit and run from the rear batts to the frame ,but you still need the 4 runs frt to back
    Yes, this. 2 runs per alt, especially if you are using 300A alts.
    i gained a whole db in the lanes by going from 4 runs of power and 4 runs of ground to 8 runs of each , just saying
    Wow, really? And that was only from front to back runs, didn't change anthing in your battery bank? What did you have up front and in back?
  4. #19
    garretttt4's Avatar
    Aug 2012
    Watertown sd
    2,456
    1 Post(s)
    1027 Post(s)
    Re: two 4ks
    4 rolls 200 ft .
    that aint TOO bad. lol u can hook me up, haha maybe help find me a alt after i get everything else from ya.
    01 Silverado 2500hd
  5. #20
    gckless's Avatar
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Re: two 4ks
    Quote Originally Posted by garretttt4 View Post
    Well then come on man, you can't see the difference in draw vs. supply here? If you want to go single, you have to realize that you won't be able to play it up high for a long period of time, and that your voltage is going to be sitting lower, because you are drawing from the batteries.
  6. #21
    bgowdy's Avatar
    bgowdy is offline HE NEEDS SOME MILK
    Apr 2011
    Campbellsville, Ky
    7,837
    71
    2 Post(s)
    2487 Post(s)
    Re: two 4ks
    seeing i have the mojo 4kw as well i figured i would share this, i read before that it has the potential to pull 400amps. on music probly not however
    06 DODGE STRATUS SXT
    Subs: Sundown ZV4 15 D1 Rev1 Motor/Rev2 Softies
    Enclosure: 3.85 Cubes Net Tuned 36hz
    Amp: Soundstream Ta.3kw @ .5ohm
    Stock 120a Alt ~1 XS D3400 & 1 Kinetic HC1800 ~ Multiple runs of Bullz Audio 1/0
    Loudest Build Score ~ 148
    F.C.B.C. > 2010 450 Street 3rd Place Overall > 2011 450 Street Champion
    YOUTUBE SEARCH->bgowdy31 & bgowdy3131
  7. #22
    garretttt4's Avatar
    Aug 2012
    Watertown sd
    2,456
    1 Post(s)
    1027 Post(s)
    Re: two 4ks
    ya thats what i thought. 8 is a lot of wire.... idk ill prolly end up doing it anyways.... im getting all my subs and wire from him anyways...
    01 Silverado 2500hd
  8. #23
    garretttt4's Avatar
    Aug 2012
    Watertown sd
    2,456
    1 Post(s)
    1027 Post(s)
    Re: two 4ks
    Quote Originally Posted by bgowdy31 View Post
    thanks for that! now i actually know what to fuse to. mostly gunna be music but will go to a few comps if they're close enough...
    01 Silverado 2500hd
  9. #24
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    Re: two 4ks
    one odessey pc 2150 in the froand one in the back .garrett , those amps can draw 400 amps very easy at high power ,from what we have been talking about you'll need everything i'm talking about if you wanna beat that guy . also the 8 runs of power and 8 of grounds actually help keep the rear batts charged when playing , also you may wan external voltage regulators .maybe even look into a 16volt system ,those memphis amps really wake up at 18 volts ,you would be syurprised what they are capable of at that voltage
  10. #25
    bgowdy's Avatar
    Apr 2011
    Campbellsville, Ky
    7,837
    71
    2 Post(s)
    2487 Post(s)
    Re: two 4ks
    your saying run 2 wires from the ALT? I'm just curious if i should do this?
    Sorry garretttt4, not trying to steal your thread just trying to learn alittle bit lol.
    ---------- Post added at 12:39 AM ---------- Previous post was at 12:38 AM ----------
    NP.....
  11. #26
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    Re: two 4ks
    yea we can work something out
  12. #27
    garretttt4's Avatar
    Aug 2012
    Watertown sd
    2,456
    1 Post(s)
    1027 Post(s)
    Re: two 4ks
    is the odessey a batt? just two of them?
    ---------- Post added at 09:40 PM ---------- Previous post was at 09:40 PM ----------
    good haha
    01 Silverado 2500hd
  13. #28
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    Re: two 4ks
    yes its the batts that i run,i have the 2 still ,bad azz batts too
  14. #29
    garretttt4's Avatar
    Aug 2012
    Watertown sd
    2,456
    1 Post(s)
    1027 Post(s)
    Re: two 4ks
    idc haha
    ---------- Post added at 09:43 PM ---------- Previous post was at 09:42 PM ----------
    text me a price. sounds sweet just having two batts, and sounds like theyll be expensive batts haha
    01 Silverado 2500hd
  15. #30
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    Re: two 4ks
    idc haha
    these batts are expensive ,but with what you are trying to accomplish you'll need at least 6 of these to get there 500 each new .
  1. 30cubes, two 18s and 4k rms
    By phuck CA.com in forum Enclosure Design & Construction Help
    Last Post: 11-10-2010, 04:45 PM
  2. WTB: Two 18's that can take 4k
    By anj46907 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 08-16-2009, 02:02 PM
  3. WTB 2k - 4k AMP FOR MY TWO 15" TYPE-R
    By xSX450 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 07-16-2008, 11:16 AM
  4. Replies: 5
    Last Post: 12-18-2001, 01:32 PM
