+ Reply to Thread
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 46
Reload Thread: headlights dimming
  1. #31
    SourDeez's Avatar
    SourDeez is offline CarAudio.com Veteran
    Apr 2007
    Fuqy u
    4,129
    62 Post(s)
    Re: headlights dimming
    Quote Originally Posted by NASTY08IMPALA View Post
    Add a extra ground straight to neg battery post
    ---------- Post added at 04:47 PM ---------- Previous post was at 04:46 PM ----------
    That kind of power at 2 ohms should not be dimming much at all with you.re setup
    This.
    Headunit - Stock cassette player - Pioneer P9400
    Front Stage - Pyle 8 inch subs (1000 watt peak!!) - Polk DB6.5 (about to be CDT 6.5s)
    Rear stage - Deleted (stolen) - Deleted
    Sub stage - custom built 15 inch sony xplod (5k watt peak!!!) (huge box) - Two SA12's built by Corey
    Sub amp - Pyle 8000w peak!! (spl edition) - AQ2200
    Electircal - 35 amp alt from ford festiva upgrade, stolen battery, 28 gauge solder coil for my cable - Dual D34 Yellows, 1/0 trystar OFC, 135amp alt
  2. #32
    kirby mane's Avatar
    kirby mane is online now Member
    Nov 2012
    Tuscaloosa,Al
    88
    Negative battery post has factory and 1/0 gauge coming from it now did some research and ecu tells alt. How much power to put out could that be my whole problem
  3. #33
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is online now CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    3,108
    32 Post(s)
    Quote Originally Posted by kirby mane View Post
    Most new cars do this so the alt isnt taxing all the time ...not ur problem...add that ground and get back to us ..wouldnt hurt ti pick up extra agm for future upgrades
  4. #34
    SourDeez's Avatar
    Apr 2007
    Fuqy u
    4,129
    62 Post(s)
    Very possible
  5. #35
    kirby mane's Avatar
    Nov 2012
    Tuscaloosa,Al
    88
    So I'm going to have 3 grounds coming from battery should I ground to same ground as amp and battery are on now or a new one
  6. #36
    Chriszle's Avatar
    Chriszle is online now CarAudio.com Elite
    Jan 2011
    SD
    1,581
    7 Post(s)
    If all your wiring checks out, you probably have your gain set too high. You shouldn't have any trouble with dimming lights with the electrical you have now.
  7. #37
    Aug 2012
    3,108
    32 Post(s)
    Ground from the neg battery post directly to the amp
  8. #38
    SourDeez's Avatar
    Apr 2007
    Fuqy u
    4,129
    62 Post(s)
    Battery is grounded.
    Ground amp directly to negative battery post
  9. #39
    kirby mane's Avatar
    Nov 2012
    Tuscaloosa,Al
    88
    What difference does that make chassis ground is maybe 4 inches away from post
  10. #40
    SourDeez's Avatar
    Apr 2007
    Fuqy u
    4,129
    62 Post(s)
    Its up to you
  11. #41
    Aug 2012
    3,108
    32 Post(s)
    Just try it man ..we're jus tryin to help.u shouldnt have any dimming at all but u clearly have a install or equipment problem
  12. #42
    itsblown's Avatar
    itsblown is offline why is there smoke?
    Sep 2011
    Toledo OH
    1,114
    15 Post(s)
    How did you set the gain on your amplifier? you should go to an auto store and have your alternator tested, they usually do it for free
  13. #43
    kirby mane's Avatar
    Nov 2012
    Tuscaloosa,Al
    88
    Amp was set with meter and alt was tested at time of purchase
  14. #44
    kirby mane's Avatar
    Nov 2012
    Tuscaloosa,Al
    88
    I quess I'll get a second battery next week and see if that will help. Any idea what size, not trying to take up trunk with system and batteries I do like to drive it like I stole it ...sometimes lol. Thanks for all your help.
  15. #45
    Aug 2012
    3,108
    32 Post(s)
    At least a group 34.. 31 if u can fit..in the mean time try adding that ground
+ Reply to Thread
  1. Headlights dimming
    By stratusrt01 in forum General Discussion
    Last Post: 02-06-2006, 05:21 PM
  2. Headlights dimming and hu skippin
    By AudioRiot in forum Wiring, Electrical and Installation Help
    Last Post: 03-06-2005, 01:44 AM
  3. Headlights Dimming
    By pw91686 in forum General Discussion
    Last Post: 02-09-2005, 12:01 PM
  4. Headlights dim only at idle...please help
    By pudgewack in forum Wiring, Electrical and Installation Help
    Last Post: 06-10-2004, 01:16 PM
  5. headlights dimming..need advice
    By Annex in forum General Discussion
    Last Post: 10-15-2003, 11:43 PM
