Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 46
Reload Thread: headlights dimming
  1. #16
    kirby mane's Avatar
    kirby mane is offline Member
    Nov 2012
    Tuscaloosa,Al
    117
    38 Post(s)
    Re: headlights dimming
    So I cant add a hc600 or anything similar
  2. #17
    SourDeez's Avatar
    SourDeez is offline CarAudio.com Veteran
    Apr 2007
    Fuqy u
    4,210
    1913 Post(s)
    Yeah.. you can.. I dont know what size battery you use though. Look up what group size your battery is then look for good dry batteries in that size
    Or you could always wire up whatever size you want in your trunk
    Headunit - Stock cassette player - Pioneer P9400
    Front Stage - Pyle 8 inch subs (1000 watt peak!!) - Polk DB6.5 (about to be CDT 6.5s)
    Rear stage - Deleted (stolen) - Deleted
    Sub stage - custom built 15 inch sony xplod (5k watt peak!!!) (huge box) - Two SA12's built by Corey
    Sub amp - Pyle 8000w peak!! (spl edition) - AQ2200
    Electircal - 35 amp alt from ford festiva upgrade, stolen battery, 28 gauge solder coil for my cable - Dual D34 Yellows, 1/0 trystar OFC, 135amp alt
  3. #18
    kirby mane's Avatar
    Nov 2012
    Tuscaloosa,Al
    117
    38 Post(s)
    Got agm battery from orilieys redone grounds lights stil dimming but voltage is up
  4. #19
    SourDeez's Avatar
    Apr 2007
    Fuqy u
    4,210
    1913 Post(s)
    When you did big 3 did you add it to stock wiring or remove the stock wiring
  5. #20
    kirby mane's Avatar
    Nov 2012
    Tuscaloosa,Al
    117
    38 Post(s)
    Added
  6. #21
    SourDeez's Avatar
    Apr 2007
    Fuqy u
    4,210
    1913 Post(s)
    Quote Originally Posted by kirby mane View Post
    Added
    Weird, I had terrible dim with my subs (2400rms at .5 ohm) and since I did the big 3 and added two yellow tops (one in hood - one in trunk) and got a new alternator (not high output, but a new stock 130amp) I have zero dim at all
    Your alternator likely has alot to do with it
    Adding a second battery can always help too.. and its super easy to do, plus, the benefits of having dual batteries is awesome (jump your car from either side, have a backup battery in your trunk to throw in your friends dead car)
  7. #22
    kirby mane's Avatar
    Nov 2012
    Tuscaloosa,Al
    117
    38 Post(s)
    My battery is in the trunk and it and the alternator are new
  8. #23
    SourDeez's Avatar
    Apr 2007
    Fuqy u
    4,210
    1913 Post(s)
    Your second battery is in the trunk or your ONLY battery is in the trunk? How many amps is the alt
  9. #24
    kirby mane's Avatar
    Nov 2012
    Tuscaloosa,Al
    117
    38 Post(s)
    Only battery is in the trunk and alt. Is 180 amps
  10. #25
    SourDeez's Avatar
    Apr 2007
    Fuqy u
    4,210
    1913 Post(s)
    Try adding a second battery. Your alt should be more fine. Your electrical can't keep up with the amperage being discharged for whatever reason.
    Your oreilly agm is not deep cycle I believe. Maybe return that for a deep cycle (yellow top, etc)
    What amp are you running, and at what ohm?
  11. #26
    frogcase2002's Avatar
    frogcase2002 is offline CarAudio.com Elite
    Dec 2011
    hamilton, ohio
    623
    1 Post(s)
    132 Post(s)
    All grounds sanded really good and really tight? ?
  12. #27
    kirby mane's Avatar
    Nov 2012
    Tuscaloosa,Al
    117
    38 Post(s)
    Grounds r good and running Audiopipe ap1800 at 2 ohms
  13. #28
    SourDeez's Avatar
    Apr 2007
    Fuqy u
    4,210
    1913 Post(s)
    Double check your wiring and make sure you arent running it at .25 or .5 accidently (or ideally get a DMM to check)
    Triple check your grounds. A bad ground will def cause this. Is your amp grounded to your batterys negative?
  14. #29
    kirby mane's Avatar
    Nov 2012
    Tuscaloosa,Al
    117
    38 Post(s)
    Battery and amp share the same grounding point but amp is not grounded to battery post if that makes any difference and amp is seeing 2.1 ohms at terminals
  15. #30
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    Add a extra ground straight to neg battery post
    ---------- Post added at 04:47 PM ---------- Previous post was at 04:46 PM ----------
    That kind of power at 2 ohms should not be dimming much at all with you.re setup
  16. Likes SourDeez liked this post
  1. Headlights dimming
    By stratusrt01 in forum General Discussion
    Last Post: 02-06-2006, 05:21 PM
  2. Headlights dimming and hu skippin
    By AudioRiot in forum Wiring, Electrical and Installation Help
    Last Post: 03-06-2005, 01:44 AM
  3. Headlights Dimming
    By pw91686 in forum General Discussion
    Last Post: 02-09-2005, 12:01 PM
  4. Headlights dim only at idle...please help
    By pudgewack in forum Wiring, Electrical and Installation Help
    Last Post: 06-10-2004, 01:16 PM
  5. headlights dimming..need advice
    By Annex in forum General Discussion
    Last Post: 10-15-2003, 11:43 PM
