[QUOTE=gckless;8251433]Finally, a noob that knows how to look for things! Welcome!
Thanks gckless!
See this thread even helped me! I had no idea to fuse for the wire and not the equipment. It makes perfect sense tho... Wish Knukonceptz would have told me that... I'm running 0g from batteries to distro block with an inline fuse and then 4g to two amps and they told me to add up the total of the fuses in both amps and go over by 15% and fuse for that.
So if I'm reading this right I should run a 300amp fuse since I'm using OFC 0g from the batteries then?
Sorry not trying to hyjack the thread.
Bought from: flastrongman, nitefury 360, luckyderder, Jayzbent, fasfocus00, flaboy22, oldschool4me, Chevy Blazin', Inter007
Traded with: mylows10 Sold to/traded with: garychoffman, juanmgarza, 04murdalanche, Markyg66
http://www.caraudio.com/forums/itrader.php?u=1018999
I buy broken or blown amps/subs (only good ones).
They are not wrong. You can always fuse lower, just never higher. Also, you need to fuse every time you switch wire size/capacity. So, in your case I would suggest a 300A on the 1/0ga, and then 150A at the most on each of the 4ga wires. Personally I fuse for the wire (largest capacity the wire can carry) for the main run and then for the equipment (what Knu told you) after the distro block.
You will want 1/0ga between batteries almost always.
Since this thread seems to be getting some really good advice anyone care to take a look at this thread in Wiring, Electrical and, Installation help called ***** See what you think? *****
I can't seem to get anyones opinions.
It is called ***** see what you think? *****
I will warn ya it is long tho lol.... I should have made it shorter and divided everything up and put them in their respective sections.
Bookmarks
