+ Reply to Thread
Results 1 to 7 of 7
Reload Thread: Remote Wire Troubleshooting
    sizzl3r's Avatar
    sizzl3r is offline Senior VIP Member
    Jul 2010
    Minnesota
    166
    sup /wiring
    Since I'm upgrading systems, I was in the process of doing some rewiring for my truck. I got everything wired last week so I had my power wire just chilling in the back, and it some how touched the remote wire and sparked a bit. I know that's bad, but I didn't think much of it. When I got everything wired to the amp and turned the deck on, amp didn't turn on.
    I figured it wasn't my ground because if it was, the amp would still turn on but go into protect mode. We brought out the multi meter and the power wire just fine. Checked for conductivity in the blue remote wire, and the wire itself was fine.
    This leads me to believe the remote wire from my deck is completely fried. What the heck can I do to make this sucker work again? I'm so close to installing a new system and of course I run into an obstacle like this. Do i have to get a new deck? Are there ways around this?
    Thanks so much guys.
    2004 Honda Civic LX
    MTX 600XD
    12'' Orion H2 12.4
    Bought From: loudstratus, haunther
    Scammed once
    neo_styles's Avatar
    neo_styles is offline AKA Pop Twidget
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Re: Remote Wire Troubleshooting
    Try tapping your remote signal from a separate 12v wire? Should be tons of accessory wire to tap off, just need to narrow it down on where to look.
    Imtjnotu's Avatar
    Imtjnotu is offline Me Gusta Edition
    Nov 2006
    San Diego CA
    12,340
    134 Post(s)
    Ya look for an ignition wire else where..tap into it and see if the problem is still there...but if your remote wire reads 12v now then its not the remote wire...
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Conductivity check or continuity check btw? If it's the beep test, that's continuity. Won't tell you if you have power coming out of the wire.
    Imtjnotu's Avatar
    Nov 2006
    San Diego CA
    12,340
    134 Post(s)
    What he shohld do first is just jump the amps 12v power in to the remote wire in on the amp and see if its still a problem
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    ^^^That. Just don't leave it that way or you'll come to your car and battery no worky worky.
    I'm logging off for the night though. Hope you figure it out.
    sizzl3r's Avatar
    Jul 2010
    Minnesota
    166
    Tried tapping into the ignition wire(s), had no luck. Definitely should have worked. So I checked my fuse box....I HAVE MISSING FUSES. Pretty sure once I replace the missing fuses (like wtf) the ignition wire should work, and hopefully that should get it working. Hopefully. Gonna do that another day when its light. Thanks for the respnses.
    2004 Honda Civic LX
    MTX 600XD
    12'' Orion H2 12.4
    Scammed once
+ Reply to Thread
  1. Remote Wire colour????
    By Sound Gorillaz in forum Wiring, Electrical and Installation Help
    Last Post: 06-10-2002, 08:23 PM
  2. what does the remote wire hooks up to?
    By tell600 in forum Wiring, Electrical and Installation Help
    Last Post: 05-18-2002, 10:06 AM
  3. Replies: 1
    Last Post: 04-18-2002, 05:38 PM
  4. remote wire of my aiwa cdc-mp3???
    By Geo_Demon in forum Wiring, Electrical and Installation Help
    Last Post: 04-14-2002, 01:40 PM
  5. remote wire
    By Pathfinder in forum Wiring, Electrical and Installation Help
    Last Post: 03-08-2002, 09:45 PM
Tags for this Thread
