+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Reload Thread: 2 channel amp , 2 subwoofers 4 ohms help! ! ! ! !
    ElOsito's Avatar
    ElOsito is offline Junior Member
    Jul 2012
    Los Angeles
    28
    Well im having trouble with this setup , i had it connected , bridged. the positive to the positive , negative to the negative. They came in a factory box already connected. But im having trouble , everything was fine , was bumpin for awhile like an hour , then it just shut off. Now every 10mins or so , it just shuts off on me. What would be the problem? has it happened to anyone?
    Fi-brations's Avatar
    Fi-brations is offline This is too much fun
    Sep 2011
    Memphis, Tn
    910
    13 Post(s)
    Re: 2 channel amp , 2 subwoofers 4 ohms help! ! ! ! !
    gonna need WAY more information than that, what amp, what subs, what ohm rating are they, how are they wired inside the box, how is the amp wired to the box...
    sounds like the amp is going into protect though
    Head Unit: Eclipse CD7000
    Front Stage: HAT Legatia L6V1, Clarus C1
    Front Stage Amplifiers: Xtant 4180c, 2100b
    Sub Stage: IA Flatlyne 18" For Sale
    Subwoofer Amplifier: Alpine MRV-1507 For Sale
    StarMountainSound Box
    Business with: davidtemple(x2), infamous_e46, Bettrn'Reverse, splaudio, TaylorFade, Tallc, Louisiana_Crx, RidnClean, b.mena, Mike Burke, Gameovercca, Ram_Designs, Double 07
    neo_styles's Avatar
    neo_styles is offline AKA Pop Twidget
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Probably not 2 ohm stable bridged.
    dragnix's Avatar
    dragnix is offline LXIX
    Dec 2006
    Socal cuz i'm So cool
    19,347
    21 Post(s)
    you need to find out what ohm they're wired at from the factory
    Got a pm regarding my sig
    Quote Originally Posted by audioholic
    please change it to something non-******. thankyou.
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    If it's a prefab I'm guessing SVC 4ohm on each which would render a 2 ohm load. I know a lot of amps aren't stable bridged at 2 ohms and that's my guess as to what's happening.
    dragnix's Avatar
    Dec 2006
    19,347
    21 Post(s)
    could be, and if that's the case that amp is fuxored
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Yep, he probably blew something
    ElOsito's Avatar
    Jul 2012
    Los Angeles
    28
    Quote Originally Posted by dragnix View Post
    what you mean fuxord?
  9. #9
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    He means you overloaded your channels and probably blew something inside the amp. Disconnect everything and inspect the internals or if you're worried about that, see what you can smell. If it smells crispy, you're done.
  10. #10
    ElOsito's Avatar
    Jul 2012
    Los Angeles
    28
    Quote Originally Posted by Fi-brations View Post
    Not sure , its prefab , and its 2 kickers , 4 ohms each , the amp is kenwood kac 301xt i think.
  11. #11
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Amp is not 2 ohm stable bridged. Try connecting your subs to one channel of the 2-channel amp and see if you can recreate the issue.
  12. #12
    Sep 2011
    Memphis, Tn
    910
    13 Post(s)
    turning on and off every ten minutes sounds more like going into protect from having a too low impedance on the amp, however you will eventually blow ur amp if u havent already
  13. #13
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    If you're savvy enough to check the wiring on your subs, make sure you're in series between each sub. You'll put an 8 ohm load on the amp which it CAN handle bridged.
  14. #14
    ElOsito's Avatar
    Jul 2012
    Los Angeles
    28
    Yeah i think its happened to me before with an alpine amp , it smelled burnt lol. well this one hasnt just yet really , atleast dont think , i mean it still turns on , but i just disconnected for the mean time , didnt want it to happen again , if it hasnt already. How do u kno if its blown?
  15. #15
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Visual inspection of the internals. Voids warranty somtimes, though.
+ Reply to Thread
  1. 5 channel amp ~50x4 @ 4 OHMS and 600x1 @ 2 OHMS
    By springy101 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 04-14-2008, 01:40 PM
  2. 4 channel amp 2 different ohm loads?
    By puppie_chow in forum Amplifiers
    Last Post: 02-23-2005, 01:03 AM
  3. Alpine 3566 6 channel amp, please read...Need help asap.
    By ActionJ-01-Z71 in forum Amplifiers
    Last Post: 03-21-2004, 01:46 PM
  4. can i bridge a 2 channel amp to 2 ohms?
    By Terminator in forum Wiring, Electrical and Installation Help
    Last Post: 10-16-2003, 02:37 PM
  5. Amp To Subwoofer Connection Help
    By ghripp in forum Wiring, Electrical and Installation Help
    Last Post: 02-09-2002, 06:38 PM
Tags for this Thread
