+ Reply to Thread
Results 1 to 11 of 11
Reload Thread: 4 channel amp, 2 door speakers and 1 sub
    rovertnamrod's Avatar
    rovertnamrod is offline Junior Member
    Nov 2012
    florida
    22
    i'm looking at getting the mb quart onx4.80 amplifier (puts out 80 watts rms x 4 channels at 4 ohms). i'm also looking at the alpine type r components (spr 50c) for my doors, which put out 100 watts rms at 4 ohms each speaker. i'm also looking at the infinity reference 1260w subwoofer which does 300 watts rms at 4 ohms.
    the amplifier puts out 320 watts rms x 2 channels at 4 ohms when bridged. i know i can simply use 2 of the amp's channels and power the 2 alpine speakers with those 2 channels, therefore giving each of the speakers 80 watts each. and i know i can bridge the other two channels into 1 channel and power my sub that way.
    my question is instead of just powering the 2 alpine components with 2 seperate channels at 80 watts rms each, could i put both of those speakers on ONE BRIDGED CHANNEL.? again, the amp puts out 320 watts rms x 2 channels when bridged. i would like the sub to get one of those channels, and the two speakers to get the other channel. if i can do this, does that mean my 2 speakers would get 160 watts rms each, and my sub would get 320 watts rms?
    (i'm not getting rear speakers and i know i may have to adjust the gain on the amp)
    Nov 2012
    florida
    22
    Re: 4 channel amp, 2 door speakers and 1 sub
    anybody?
    WinC101's Avatar
    WinC101 is offline Senior VIP Member
    Oct 2012
    Bonaire
    152
    1 Post(s)
    Bridge the 2 speakers on 2 channels..and the sub for the other 2 channels. you should do fine
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    61
    3,243
    8 Post(s)
    Quote Originally Posted by rovertnamrod View Post
    No. First off, running 2 speakers off the same amp channel will create a 2 ohm load (two 4 ohm speakers), and your amp won't handle that in bridged mode. Secondly, you'd lose stereo - both speakers would play the same combined L&R program. And lastly, the speakers are rated at 100 watts max, why would you want to power them at 160 each?
    Stick to the original plan. 80W each is perfect for those speakers.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25
    Sub Stage: In process (will be Boston G310)
    Amp: Boston Acoustics GTA-704 4 Ch
    Rear Fill: Boston SE953 6X9's
    Kingstroker's Avatar
    Kingstroker is offline Mr Dique
    Oct 2012
    Guthrie, OK
    330
    1 Post(s)
    Quote Originally Posted by WinC101 View Post
    if you do you will not have stereo, only mono on your fronts and no balance controls.
    WinC101's Avatar
    Oct 2012
    Bonaire
    152
    1 Post(s)
    Yup.. Mono and it gets louder than if you wire them each in one channel.. I love em loud!
    Quote Originally Posted by Kingstroker View Post
    Oct 2012
    Guthrie, OK
    330
    1 Post(s)
    Nov 2012
    florida
    22
    160 each just for "headroom." i would not actually give the speakers that much power as i would adjust the gain on the amp. but with only 80 watts, my speakers wouldn't live up to their full potential.
  9. #9
    Nov 2012
    florida
    22
    ok so if i give each door speaker 80 watts while my sub is pushing 300 watts, is my sub going to drown out the music with too much bass? i am just looking for a high sound quality, balanced setup- not extreme loudness.
  10. #10
    maylar's Avatar
    Jan 2002
    Connecticut
    61
    3,243
    8 Post(s)
    Too many variables to predict which will be louder, but you can balance it out by adjusting the sub gain if you have to. Believe me, 80 watts per speaker can be rather loud.
    dave
  11. #11
    keep_hope_alive's Avatar
    keep_hope_alive is online now Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    5,031
    28
    124 Post(s)
    agreed with Mylar. subs are less efficient, and our hearing is less sensitive so we need more power to subs than speakers to result in the same "loudness".
    maintain a stereo signal to the fronts and bridge the sub - that is a tried and true method.
    have you been helped by me? i'd love to know. shoot me a PM.
    My 2001 Accord build log:
    http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Can I help you? valencebandacoustics@gmail.com
    Want to learn about car audio electronics?
    http://www.bcae1.com
+ Reply to Thread
  1. Bridge two amps for door speakers and subs
    By Nesto1000 in forum Wiring, Electrical and Installation Help
    Last Post: 10-09-2011, 01:48 PM
  2. Problem wiring door speakers and sub to same amp
    By newsomjk in forum Wiring, Electrical and Installation Help
    Last Post: 05-04-2010, 05:16 PM
  3. Replies: 2
    Last Post: 08-19-2008, 10:59 PM
  4. ? about runnin 4 channel amp for speakers and subs
    By Alpine4x4 in forum Amplifiers
    Last Post: 07-27-2006, 08:20 PM
Tags for this Thread
