sounds like more than one problem...wiring and electrical problems can be confusing and a bitch. ive never gotten everything perfect the first time i install something
Head Unit: Eclipse CD7000Business with: davidtemple(x2), infamous_e46, Bettrn'Reverse, splaudio, TaylorFade, Tallc, Louisiana_Crx, RidnClean, b.mena, Mike Burke, Gameovercca, Ram_Designs, Double 07
Front Stage: HAT Legatia L6V1, Clarus C1
Front Stage Amplifiers: Xtant 4180c, 2100b
Sub Stage: IA Flatlyne 18" For Sale
Subwoofer Amplifier: Alpine MRV-1507 For Sale
StarMountainSound Box
So what your saying get new wire to rewire the battery power wire to alt, Re wire the battery ground and re wire the alt ground? Also I think I got this part fucked up, I wired my amps ground to the batteries ground, what I should of done was wired the amps ground to the batteries negative terminal? I just want to make sure I clarify everything so there will be no miss-communications again!![]()
So what do you think it could be? Personally the wiring from the battery to the alternator could be bad and that what made sense to me about the car not starting up but what doesn't make sense to me is how can the amp not turn on unless I turn off the car and jiggle the power wire to the fuse.
do u own a dmm? check all of your powers, grounds and remote wires for a bad or loose connection, it's gonna take time and u might have to pull up all your wire and hunt for it, but ive had to do it several times. One time a wire had come undone behind the hu and i forgot i had tapped in back there, made sure to solder it that time. And just yesterday i got my replacement HAT C1 tweeter from Scott b/c for some reason i wasnt getting sound from that tweeter, checked all my wiring 3 times, swapped in another tweeter and it worked perfectly, checked the ohm rating on the other one and nothing...open circuit
HU: KDC-X994
Front stage: Phd FB 6.1PRO KIT, Active
Sub stage: 1st gen RE XXX 12" w/Fi recone
Highs Amp: Kenwood Excelon XR-4S
Lows Amp: Mmats D300hc
The Rest: AT 60 mil, Optima Redtop underhood and Yellowtop in trunk, Big 3 and front to rear +/- runs in Monster Cable 1/0
Bookmarks
