Re: Something is going bad in my audio setup
gotcha..I am using all 3 pairs of pre outs so I don't have any rca jacks left. I do have a peice of frame right behind the HU I can mount to. Could I just use a single wire, attach one end to a screw on the HU and the other to the frame? I have always had alternator wine, but only notice it when no music is playing
Quote:
Originally Posted by
rondog
I had the exact same problem with mine. I was going through the factory harness ground and switched it over to a short 12" piece of wire to the frame and although it didn't cure it completely, it's tons better. Before it was all hell.
rondog
yes you could do that,it might not stop it completely,but it will definitely help out
I wonder if one of those 10 amp noise filters would work? like the pac CSS-100 or something...
my 1 month old pioneer premier just started having ground noise...
why not use a ground loop isolator?
