Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Reload Thread: Keep Blowin' Type-R's
  1. #16
    DoesDad's Avatar
    DoesDad is offline CarAudio.com Veteran
    Dec 2011
    Tulsa, OK
    2,342
    675 Post(s)
    Re: Keep Blowin' Type-R's
    Are there any reputable shops near your house? You need a little help. For one thing don't use the bass boost. Ever. And don't adjust things like the gain while the music is "blaring". If I were you I'd make another thread and see if maybe there's someone near you that could give you a hand. Your subs are 600 watts a pc. by the way. Under powering them isn't going to be a problem but at the same time I think you might be expecting to much out of the amplifier and pushing them to hard. Someone had said you can't blow a sub underpowering it. Yes you can if clip the shit out of it....
  2. #17
    tc300's Avatar
    tc300 is offline CarAudio.com Veteran
    Mar 2007
    springfield,ill
    3,015
    605 Post(s)
    If it was being underpowered I'm pretty sure he turned the gain up and the bass booster there for clipping it to death....... And box size will come into play also
  3. #18
    tc300's Avatar
    Mar 2007
    springfield,ill
    3,015
    605 Post(s)
    One reason why I run mmats is that they have no bass boost so I don't have to use that.. I do try to get the most out of my cabin gain tho! :-). All mmats has is gain and xover... Sometimes less is more...
  4. #19
    whitedragon551's Avatar
    whitedragon551 is offline Moderator
    Mar 2009
    IL
    13,560
    39 Post(s)
    1406 Post(s)
    Use this guide here to set your gains for your subs:
    How to Set Gains with a DMM
    Remember gain is not a volume control.
    Set them using a 50Hz 0db tone. Never turn the bass boost up or the loud setting on if your head unit/amp if it has one. They increase distortion and clipping. They are blowing because your clipping them.
    Id recommend starting at Basic Car Audio Electronics to learn some of the basics on car audio.
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
  5. Likes tc300 liked this post
  6. #20
    Better-Action's Avatar
    Better-Action is offline give me a reach around
    Sep 2012
    SD
    438
    167 Post(s)
    If you have to have your bass boost all the way up to like the sound..... you need a much bigger amp. You don't have the power to push them like you want. Putting bass up on the headunit, loud on and bass boost all up on the amp, causes your amp to clip. Clipping will cause the amp to overdrive itself. It WILL be louder clipping like this because your amp is putting out more power. The problem is your amp is not designed to put out that power so it is dirty power. Dirty power causes heat. And heat killed your subs. BASS BOOST OFF!! loud off. Bass on headynit at least at 0. If you use these settings then set Yuri amp correctly, and it isn't loud to your liking.... you need a bigger amp period. On my setup now I got loud off. Bass neg as far as it goes, -6. Bass boost all the way down. Gain at a little over half. And because I got the power it pushes that sub hard.
    Op... buy a bigger amp. I'd say look for one that does 1,500 rms at the impedance load you need.
  7. #21
    jungstah's Avatar
    jungstah is offline Senior VIP Member
    May 2012
    san francisco
    278
    78 Post(s)
    Please take the advice given to you, TURN THE BOOST DOWN. turn your headunit up until the point of distortion, general rule of thumb is about 75% of your volume. Then with a test tone playing, probe the speaker terminals to check for AC voltage and get it to put out the proper power. Your subs may slam with bass boost cranked, but they are dying from getting clipped. I bet it sounds like azz as well.
    And you are setting the amp silently? U scared to play music or somethin wtf?
    Pioneer AVH-P2400BT
    Stock Pioneer 4" components
    Hifonics Brutus BRZ1700.1D
    Two SA-12's
    cruddy prefab ported box----new box otw
  1. keep blowin fuses
    By Skeeter51 in forum Wiring, Electrical and Installation Help
    Last Post: 09-28-2006, 04:55 PM
  2. Distro Block keeps blowin sub fuse.
    By Silver in forum Wiring, Electrical and Installation Help
    Last Post: 09-11-2005, 12:42 AM
  3. HU fuses keep blowin' out??????????Help???????
    By Gomab02k in forum Head Units
    Last Post: 07-27-2005, 09:59 PM
  4. Amp Keeps blowin fuses
    By Mash Jetta TDI in forum Amplifiers
    Last Post: 07-02-2005, 11:41 PM
  5. keep blowin subs...
    By Strecker25 in forum Subwoofers
    Last Post: 04-10-2004, 01:09 AM
