How your voltage I think two runs will be fine I'm definitely not at .35 either haha
bought from: wccoug21 sundownz thegreatestpenn loudwhat? woofercooker jonny101abc spooney fasfocus00
sold to: jpx18 Nateberrier Ge_off_me spm_215 2lo2flo akheathen etm34 djjdnap jfroghobo traded: SPLaudio Zeuslicious
under construction:
1992 Toyota Paseo(1) Pioneer DEH-P500UB head unit(2)American Bass VFL 500.1 amps(4) stinger batteries,building 2 10's in tubes
That's what I thought... I'm about to post some more pics of the stuff I got today look out for it...
Team Flex Issues
4 18" Mayhems
2 bc5500's
Bought from: ameduce(x2), Hatchet_Warrior, jeeper07,DB_DRAG_SPL,ssackett, lyttleviet,MillzThaYungin, blackbonnie, ryan1126, Goindef154(x2), Lonnie, dave_damage
Sold to: Ilovebass, nismos14, chednompton, teen, jonesy
Good so I should expect to stay in the 13's... What do you have mids and highs wise?
Assuming your batt bank is close together why would you do multiple runs between batts? 1/0 will carry a LOT of amperage over a 2-3' run.
2 runs POS from the front should be fine for that alt/batt combo up front. A 3rd run wouldn't hurt, but probably wouldn't help either...
If you can fit it, I'd just do a single run of 4/0 welding cable. That stuff is rated for like 600 amps at a 50' length. Less than half a volt drop per 10' at 1000A of current according to the datasheets I've read. Then all 2/0 or even 1/0 if lengths are less than 5' between batteries and amps. Just my $.02. You can buy 4/0 for only slightly more than the high-end 1/0 car audio wire, and it has about three times the current carrying capacity and about half the resistance. These are all rough numbers I'm shouting out, so if I'm off a little, I apologize.
Bookmarks
