+ Reply to Thread
Results 1 to 8 of 8
Reload Thread: 02 Accord Setup
    Dbruckn's Avatar
    Dbruckn is offline Junior Member
    Nov 2012
    South Carolina
    02 Accord Setup
    Hey guys,
    I've been playing around with my setup today, and thought you guys could help me figure out what to do. I've got a 15" Kicker L5 in the trunk of my 2 door 02 Accord. It sounds alright, but it's not nearly as loud or clear as I think it should be. So I dropped down my back seat, and it sounded much better.
    I can't really drive around with my backseat down, so do you guys have any idea how I might get some more sound through the rear deck into the main cab of the car? Right now it is just going through the holes where the speakers used to be.
    Thanks in advance!
    audiobaun's Avatar
    audiobaun is offline Premium Member audiobaun is a Supporting Member of the forum!
    Jun 2011
    rockwall,Tx
    5,892
    36 Post(s)
    Re: 02 Accord Setup
    Not a whole lot you can do with that without spending some money to do some modification to the rear seat/remove,and wall it up.You have like a a wall seperation so to speak,listening to the bass from the room next door.you can get more power/heavier rms made sub maybe, or just keep both seats down/or one,or place the sub in the back seat,or sell the car, and get something where the sub will be inside the cabin space with you.May be able to Modify the back deck/remove/and make one in place/frame up,and use speaker cloth.I just rode around with one seat down.Just one extra step when getting in, and getting out to put it back up
    Dbruckn's Avatar
    Nov 2012
    South Carolina
    Re: 02 Accord Setup
    Yeah, that's kind of what I was thinking. The current amp is mounted to the back of the seats, and is too big to be on just one or the other. I might just look at a different amp placement and just let one seat down.
    audiobaun's Avatar
    Jun 2011
    rockwall,Tx
    5,892
    36 Post(s)
    Re: 02 Accord Setup
    Quote Originally Posted by Dbruckn View Post
    You can build an amp board on the side of the trunk space, and mount that amp horizontal/long ways,you will also get some cooler air in there too with seat down
    audiobaun's Avatar
    Jun 2011
    rockwall,Tx
    5,892
    36 Post(s)
    Re: 02 Accord Setup
    Well here is an idea of mounting option i am talking about,SStream has a great concept going for Mounting options out of the box ides,and saves space,Who says amps need be laid down ect?Vertical..lol not horizontal ..my badd..Something to think about.Amp board coverings are unlimited too/
    http://www.ebay.com/itm/DTR4-680-4-C...item20cdb02527
    Jun 2010
    Milwaukee
    142
    Re: 02 Accord Setup
    Alright do as follows: Copy and paste this setup into your Accord for some awesomeness that will, break your rear view mirror, break your sunroof, start tearing seals off your roof, etc... I also do not drive with the backseat down at all...
    Gotta have Fix a Flat and air pump because you won't have a tire
    There is also a Group 31 battery in a custom built cage using the spare tire mount and wing nut.
    Ported into Rear deck. Sealed 100 percent from cabin into trunk.
    Make sure to lock your trunk opener and only allow it to be opened by a key...
    Some quick tweeter mounts I whipped up a while ago.
    Add red glow to increase your ***** size.
    Bought From: fasfocus00, ilkman2202, Bad4health, 90accordman
    Sold to: vitveet, sacskings916, binks.333.binks 100% on eBay 140+ ratings
    My Ride: 2002 Honda Accord 2.3L
    - Alpine 9887 TruRTA
    - 2x DC XLs 12" on a DC 5K!
    - Hertz 165XL on DC175.4 (Active)
    - 2 Runs of 1/0 Fleks and 1/0 KCA
    - Will not support my alternator company. Ask why.
    - D34 Optima Yellow Top, XS D3100
    audiobaun's Avatar
    Jun 2011
    rockwall,Tx
    5,892
    36 Post(s)
    Re: 02 Accord Setup
    Power!!! 5 k amp for the subs should get r done..LOL!!
    heebs 09gts's Avatar
    heebs 09gts is offline Senior VIP Member
    Jun 2012
    VanCity
    453
    Re: 02 Accord Setup
    My car has a arm rest in the middle of the back seat. I cut out a rectangle hole in the back seat, right behind the arm rest. So when the arm rest is down, i get lots of bass coming through there. But then I can always fold the arm rest up and it covers up the hole.
+ Reply to Thread
  1. 98-02 Accord Coupe Door switches $50
    By JayRich in forum Miscellaneous Classifieds
    Last Post: 05-26-2009, 02:56 PM
  2. 98-02 Accord parts..
    By lashlee in forum Miscellaneous Classifieds
    Last Post: 04-19-2008, 07:39 PM
  3. 02 accord kick
    By Kaizer_Sozay in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 08-31-2005, 06:29 PM
  4. How to install '02 Accord OEM headunit into '94 Accord?
    By Y2A in forum Enclosure Design & Construction Help
    Last Post: 07-09-2003, 03:29 AM
