Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Reload Thread: Gotta fix my ground... Will this work?
  1. #16
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Re: Gotta fix my ground... Will this work?
    Quote Originally Posted by alec14 View Post
    do you mean the positive?
    No, he means the ground.
  2. #17
    alec14's Avatar
    alec14 is offline CarAudio.com Elite
    Aug 2012
    Alpena, MI
    1,818
    665 Post(s)
    Quote Originally Posted by gckless View Post
    okay, understood now
    Bought from: flastrongman, nitefury 360, luckyderder, Jayzbent, fasfocus00, flaboy22, oldschool4me, Chevy Blazin', Inter007, dross93ranger, 04murdalanche, glitchsta, photocrazy8, 2002XLT
    Traded with: mylows10 Sold to/traded with: garychoffman, juanmgarza, 04murdalanche, Markyg66, basswiigee, btolenti, supereikenator, shauncox26, eg9(x2), big scott, bad @SS chevy
    http://www.caraudio.com/forums/itrader.php?u=1018999
  3. #18
    hcivic91's Avatar
    hcivic91 is offline Member
    Apr 2011
    DC
    45
    27 Post(s)
    From what I understand you should not disconnect the ground with the RCA still plugged in. The RCA can serve as a grounding point back to the deck if the amp still has power from the positive lead. What can happen, in rare cases, is the input stage on the amp can fry. Its rare but I've seen it.
  4. #19
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Quote Originally Posted by hcivic91 View Post
    We're taling about removing the ground (negative) wire from the battery itself. When that's off there's no path for any current to return through.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  5. #20
    alec14's Avatar
    Aug 2012
    Alpena, MI
    1,818
    665 Post(s)
    so, disconnect the rca's?
  6. #21
    alec14's Avatar
    Aug 2012
    Alpena, MI
    1,818
    665 Post(s)
    Quote Originally Posted by maylar View Post
    could i still take the negative off the chassis without taking off the negative battery terminal, and without removing the rca's?
  7. #22
    maylar's Avatar
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    That's not recommended unless you remove the + first from the amp. Why can't you just pull the fuse? Then there'd be no worries.
    dave
  8. #23
    alec14's Avatar
    Aug 2012
    Alpena, MI
    1,818
    665 Post(s)
    this might sound incredibly stupid, but i don't know how. lol
  9. #24
    butterMilk's Avatar
    butterMilk is offline CarAudio.com Elite
    Jun 2012
    BC
    501
    182 Post(s)
    I think he means remove the fuse on the power wire, Your wire is fused right?
  10. #25
    alec14's Avatar
    Aug 2012
    Alpena, MI
    1,818
    665 Post(s)
    Quote Originally Posted by heebs 09gts View Post
    yes it is. but removing the fuse is the part i'm unfamiliar with
  11. #26
    maylar's Avatar
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    OK. Umm.... The + wire that feeds your amp(s) should come off the battery and within a foot or so of the battery there should be a rectangular plastic thingie that's a fuse holder. You just open the cover of the fuse holder, grab the fuse, and yoink. It'll be a blade type fuse (usually) with two flat prongs sticking out the bottom. When you're done fussing with wires just plug it back in and close the cover.
    That's it, bro.
    dave
  12. #27
    alec14's Avatar
    Aug 2012
    Alpena, MI
    1,818
    665 Post(s)
    That's it, bro.
    sorry, I should've specified. I know what a fuse holder, fuse, etc. all that is, lol. I just never knew how to actually take the fuse out of the holder
  1. Will this work with my component set?
    By kizzo in forum Speakers
    Last Post: 01-22-2007, 11:38 PM
  2. My box plans for 3 type-Rs. Will this work?
    By Demi in forum Enclosure Design & Construction Help
    Last Post: 07-31-2006, 01:08 PM
  3. Will this work for my setup?
    By freakishly_dead in forum Amplifiers
    Last Post: 10-30-2005, 04:46 PM
  4. Will this work for my setup?
    Last Post: 10-30-2005, 04:20 PM
  5. QLogic Box for Silverado Ext. Cab, will this work with my Adire Koda 10?
    By Getwild2 in forum Enclosure Design & Construction Help
    Last Post: 01-21-2005, 12:32 PM
