+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Reload Thread: GM stock speaker impedance?
  1. #16
    toxicmegacolon's Avatar
    toxicmegacolon is offline Junior Member
    Nov 2012
    MI
    Re: GM stock speaker impedance?
    Quote Originally Posted by maylar View Post
    Your analog ohmmeter needs to have a X1 scale and be "zeroed" by shorting the leads and adjusting the zeroing knob (assuming it's an old VOM style). DC resistance of a speaker coil reads about 20% lower than the actual impedance but it's close enough for a 2 ohm v.s. 4 ohm check. If you use a digital meter be sure to short the leads first to get the zero reading. Subtract that from your measurement.
    Thanks for the advice. I didn't even notice that mine only has the x1000 scale. Now I feel kind of stupid
  2. #17
    Kingstroker's Avatar
    Kingstroker is offline Mr Dique
    Oct 2012
    Guthrie, OK
    329
    1 Post(s)
    Quote Originally Posted by toxicmegacolon View Post
    You could hook them up to a ten billion watt amp if you wanted to. You're not going to blow your speakers unless you're either deaf, stupid, or enjoy listening to horribly distorted music.
    I guess I'm one of the many deaf, stupid and enjoy listening to horribly distorted music people who have blown speakers. I've seen both incredible cheap built factory speakers and some not so much, we have no idea which he has. It was only my opinion. If you would, let me rephrase it. I would rather wait and find some somewhat better speakers before I spent time and effort hooking a billion what amp to 10 watt speakers. Again, just my opinion.
  3. Likes southernboom88 liked this post
  4. #18
    akheathen's Avatar
    akheathen is offline trianoacitol contraceptiv akheathen is a Supporting Member of the forum!
    Jan 2011
    Anchorage AK
    31
    2,196
    22 Post(s)
    you don't have head unit power? even an aftermarket head unit can blow them if they are playing much bass. they should be either 4, or 2ohms. i think the 2", if you have them might be 6. 2ohm speakers are what they use on the bose setups, but i don't think they use them on anything else, as far as mids go. factory subs are usually 2ohms. make sure you have a good battery in that old school meter
    *IF I have forgotten to exchange feedback, please let me know*
    i buy broken amps....
    No, i will not "gift" paypal. please do not even make it awkward by asking. if the fees are an issue, I am usually inclined to add them. unless you have discount elsewhere, shipping is through usps flat rate, through usps parcel post, or through the roof..... i am in alaska. thanks
    -Heath H-
  5. #19
    Oct 2012
    Guthrie, OK
    329
    1 Post(s)
    good post Heath. My wife's G35 Bose system is probably similar, if I did anything with it I would start from scratch, lots of HU problems. Mr Colon, good luck with your system. Just looked up your car and looks like head unit replacement would be a nightmare. If I wanted better sound I would do amp and/or speakers also.
  6. #20
    whitedragon551's Avatar
    whitedragon551 is offline Moderator
    Mar 2009
    MI
    12,520
    81 Post(s)
    I don't think you can just measure speaker impedance with a multimeter -- it'll just read zero ohms. Maybe there's some way to do it that I don't know about?
    It does work. Thats what a multimeter is for.
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    A Technology Related Blog
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
  7. #21
    Nov 2012
    MI
    Quote Originally Posted by whitedragon551 View Post
    Yeah you're right. I was operating under misinformation that someone had given me that made sense at the time.
  8. #22
    Nov 2012
    MI
  9. #23
    Iosias's Avatar
    Iosias is offline Senior VIP Member
    May 2012
    United States
    408
    5 Post(s)
    facepalm#
    Refs # Tallc, CleaRSkieS, Roth, Goindef154, Kangaroux, tv559
  10. #24
    Nov 2012
    MI
    Quote Originally Posted by Kingstroker View Post
    My apologies, I was wrong. Stock speakers are amazing, don't worry about blowing them with an amp, they are made to handle lots of watts.
    Well I finally got time to run my power wire and take my dash apart and it turns out that you're mostly right. It was a little better in terms of sound quality at high volume with the amp running the stock speakers, but not enough that I'm going to leave it that way. In my vehicles of yore it was always the stock head unit that was the limiting factor rather than the speakers so adding some clean power always made a big difference. In this vehicle it seems the speakers and head unit are pretty much equal in capability (equally crappy) so the amp didn't make much difference. So either factory head-units have gotten better or factory speakers have gotten crappier, or a combination of both.
  11. #25
    Nov 2012
    MI
    Quote Originally Posted by Iosias View Post
    facepalm#
    Yeah, Yeah. Someone told me that you can't use just DC to measure true speaker impedance since it's a dynamic system. This is partially true, but yes I realize now that I was misinformed and that you can get a good idea with a multimeter.
  12. #26
    Nov 2012
    MI
    facepalm#
  13. #27
    Oct 2012
    Guthrie, OK
    329
    1 Post(s)
    I think they make them extra crappy to sell you the "premium" sound system that is just a little crappy. Like I mentioned before, my wife's G35's Bose system truly *****, subwoofer and the other 6 speakers. Seems that the sub can't be adjusted just bass for the whole system. My "dual cone" factory speakers I had in my F250 blew the Bose away.
+ Reply to Thread
  1. '95 Camry upgrade: DIN question and stock speaker cover removal
    By Llamas in forum Wiring, Electrical and Installation Help
    Last Post: 06-01-2005, 01:41 PM
  2. stock speaker grilles...
    By mgaidica in forum Subwoofers
    Last Post: 01-20-2003, 10:48 PM
  3. Stock speakers and wiring
    By Gauntlet in forum Wiring, Electrical and Installation Help
    Last Post: 11-28-2002, 07:34 PM
  4. can an amp blow stock speakers-newbie
    By GrandAmGT in forum General Discussion
    Last Post: 11-11-2002, 09:06 PM
  5. Stock speakers -vs- aftermarket speakers
    By <natem33> in forum Subwoofers
    Last Post: 01-10-2002, 09:07 PM
