Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Reload Thread: wiring question
  1. #16
    voltagexdt's Avatar
    voltagexdt is offline Member
    Nov 2012
    South Georgia
    52
    21 Post(s)
    Re: wiring question
    Quote Originally Posted by >>SQL<< View Post
    Seriously you must be the biggest butt hurt person in the entire internet.
    Shut UP Noob!
    5 1/2" speakers need a 4.4" cutout which may or may not fit in a 4x10 speaker cutout, that is why I also recommended 4" mids.
    Plywood cause it is easy to work with and if you have ever been in a older muscle car you would know that they have a thick foam dash pad over the speaker area so using plywood is just fine.
    Jezz were you bullied too much in High School or something?
    You are a acting like a thin skinned child, take a look at that. I am sure you can be a better person if you just try a little.
    LOL he said plywood. a 4.4" cutout.. i think thats still bigger than 4" ya again my math is a bit rusty.
    J & M Car Audio and Security
    http://www.jmcaraudio.net/
  2. #17
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Re: wiring question
    First thing is no head unit produces 50 watts per channel, that is a MAX rating and means nothing.
    Second while summing hte front channels (neg from on side pos from other) may work but I do not think it is worth the risk to your headunit.
    What you should do is pull the 4x10 out of there, use the speaker on 1/4 plywood to make a template. Cut out the 1/4 plywood to fit 2 - 4" or 2 - 5.25" drivers in the same spot the 4x10 went.
    Now you can run stereo front and rear and I think it will sound better.
    HU speaker outputs are identical between channels. There's no risk hooking a speaker between them. I think that's how center channel OEM setups are done. I agree that two 5.25's would be a way better idea though. And if the OP is ok with taking a jig saw to the rear deck it wouldn't take much to fit them.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  1. Quick Wiring Question on Speakers
    By Unregistered in forum Wiring, Electrical and Installation Help
    Last Post: 03-26-2002, 01:43 AM
  2. Wiring Question
    By jrivera666 in forum General Discussion
    Last Post: 03-20-2002, 09:31 PM
  3. Wiring question?
    By DB4Me in forum Subwoofers
    Last Post: 03-18-2002, 11:38 PM
  4. Amp Wiring question and Amp Selection...
    Last Post: 02-26-2002, 05:46 PM
  5. Wiring question - need help
    By <thumpinblazr> in forum Subwoofers
    Last Post: 12-25-2001, 12:32 AM
