+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 49
Reload Thread: Troubleshooting DMM not reading voltage
  1. #16
    sjv13's Avatar
    sjv13 is offline StayStrange
    Apr 2011
    Lansing, MI
    625
    2 Post(s)
    Re: Troubleshooting DMM not reading voltage
    @mylows10 ; @LBC ; @dunerider650 ;
    Alright guys, I tried it again with the subsonic filter set to 5hz (lowest), LPF set to 400 (highest), bass boost at 0, and gain was at exactly half. I tightened down the DMM's leads into the speaker wire outputs. The head unit was at 50/62, loudness off, no EQ settings, etc. The bass knob was all the way up. I played a 0dB 50hz 192kbps (only bitrate available) sine wave from realmofexcursion.com that I downloaded to my iPhone. I set the DMM to AC volts. Reading = ~ 00.21 volts. What am I doing wrong here!?
    Troubleshooting DMM not reading voltage-img_2247.jpgTroubleshooting DMM not reading voltage-img_2248.jpgTroubleshooting DMM not reading voltage-img_2245.jpg
    2000 Volvo v70
    HU: Pioneer MVH-8200bt
    Front Stage: Focal IS-165
    Sub: Alpine Type-R 12"
    Speaker Amp: Polk PA660 bridged to 150x2wrms
    Sub Amp: Alpine MRX-M50
    Sub Box: Custom, tuned to 33Hz
  2. #17
    LBC's Avatar
    LBC
    LBC is offline Banned
    May 2012
    Audio Technix
    125
    9 Post(s)
    Quote Originally Posted by sjv13 View Post
    Attachment 26537602Attachment 26537600Attachment 26537601
    Use a cd. Download the SMD DD-1 disc and use track 1. 40hz at 0db. Burn it and use that. your iphone has to be the problem. It has a volume and gain of it's own.
  3. #18
    mylows10's Avatar
    mylows10 is offline WEST COAST DC & PHD REP mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    13,109
    364 Post(s)
    pioneer avhp 4100 dvd, 2 dc lvl 4 10's custom built by Thor's hammer , ab vfl 4480
    ab vfl 150.4 ,2 pc 2150 ,
    cdt 6.5 es 61 im mids,cdt es 010 tweets with es 200 us x overs stinger hpm o gauge wires
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  4. #19
    sjv13's Avatar
    Apr 2011
    Lansing, MI
    625
    2 Post(s)
    Quote Originally Posted by LBC View Post
    My head unit doesnt have a CD player. And I'm using the USB cable with the iPhone, not the 3.5mm jack, so I thought it wouldnt matter?
    2000 Volvo v70
  5. #20
    mylows10's Avatar
    Sep 2009
    monterey , ca
    13,109
    364 Post(s)
    it still does
  6. #21
    LBC's Avatar
    LBC
    May 2012
    Audio Technix
    125
    9 Post(s)
    Unfortunately it does.
  7. #22
    sjv13's Avatar
    Apr 2011
    Lansing, MI
    625
    2 Post(s)
    Quote Originally Posted by mylows10 View Post
    it still does
    So I guess I really have no way to set my gain to the sure max safe level then...
    2000 Volvo v70
  8. #23
    mylows10's Avatar
    Sep 2009
    monterey , ca
    13,109
    364 Post(s)
    usually half is really close,but yea ,unless you can get a really good download and put it on a flash drive
  9. #24
    sjv13's Avatar
    Apr 2011
    Lansing, MI
    625
    2 Post(s)
    I put that realmofexcursion.com file on a flash drive and tried it again. All the same settings as before. Read: ~ 00.29 volts
    2000 Volvo v70
  10. #25
    mylows10's Avatar
    Sep 2009
    monterey , ca
    13,109
    364 Post(s)
    did you look at the video i sent you .it says a flat response all around loudness off unplug all rca's and use a 60 hrtz test one not 50
  11. #26
    sjv13's Avatar
    Apr 2011
    Lansing, MI
    625
    2 Post(s)
    yeah, I watched it. I unplugged the 4 channel's rcas (left the mono's in though of course). Loudness was off. All EQ settings were flat. No bass enhancements. I'll try it with a 60hz tone, but I didnt think that part mattered.
    2000 Volvo v70
  12. #27
    mylows10's Avatar
    Sep 2009
    monterey , ca
    13,109
    364 Post(s)
    let me know what you get
  13. #28
    sjv13's Avatar
    Apr 2011
    Lansing, MI
    625
    2 Post(s)
    Ok, so I found a different website. I downloaded a 705kbps 60hz sine wave in .wav format. I tried it and I am still getting the same results as before.
    2000 Volvo v70
  14. #29
    mylows10's Avatar
    Sep 2009
    monterey , ca
    13,109
    364 Post(s)
    hmm kind of wondering if something going on with the amp now
  15. #30
    sjv13's Avatar
    Apr 2011
    Lansing, MI
    625
    2 Post(s)
    When it's hooked up normally the sub plays the music perfectly fine, so I dont see how it could be an amp related problem.
    2000 Volvo v70
+ Reply to Thread
  1. amplifier not reading voltage properly??
    By Falcons in forum Amplifiers
    Last Post: 06-03-2011, 02:50 PM
  2. Help me troubleshoot....amps not coming on
    By zachzchw in forum General Discussion
    Last Post: 05-11-2005, 11:08 PM
  3. DXZ825 not reading CD-Text
    By Pilotman28 in forum General Discussion
    Last Post: 05-11-2003, 01:10 AM
