+ Reply to Thread
Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 52 of 52
Reload Thread: sub barely audible
  1. #46
    zaylor's Avatar
    zaylor is offline Junior Member
    Nov 2012
    United States
    Re: sub barely audible
    Quote Originally Posted by >>SQL<< View Post
    Well I am going to conclude that the setup you bought is bad / broken.
    Truthfully it was not really a good product / solution to anyway.
    I think you should buy a amp, subwoofer , wiring, and a box - it is not that hard and you will have something that would sound good for a long time.
    A $200 budget would be decent
    It could be done for less but not worth it IMO
    A $300 budget would get you something that you would really be happy with.
    So what do you think would be best for you?
    It is in a small reg cab pickup. I didn't want anything pounding, just something to fill out the lower end. This was a good option because of how little space it took up.
    If the unit is really broken, I will probably pull it apart and have a look.
    I wish there was a more conclusive test I could do.
  2. #47
    >>SQL<<'s Avatar
    >>SQL<< is offline CarAudio.com Elite
    May 2011
    USA
    1,461
    1 Post(s)
    Well there are more test you can do.
    Either the internal amp or the sub is broken.
    If you want it would not be hard to either replace the bad sub with a new one or replace the amp with an external one.
    Do you have a DMM (multi-meter)?
    Quote Originally Posted by zaylor View Post
  3. #48
    zaylor's Avatar
    Nov 2012
    United States
    Yes, I know how to use it.
  4. #49
    >>SQL<<'s Avatar
    May 2011
    USA
    1,461
    1 Post(s)
    OK pull the sub out, disconnect it from the amp, check for resistance across the speaker wire terminals.
    Should be 4 ohms most likely
  5. #50
    zaylor's Avatar
    Nov 2012
    United States
    The resistance across the sub's terminals was about 5.8ohms on either side. Though I don't trust my dmm for small ohm values that much.
    I made a video so that people can give me opinions on whether it's how loud it's supposed to be. I know video is a crappy way to gauge loudness, so hopefully you can contrast with my voice. Is this it? - YouTube
    This is with every setting maxed out.
    It draws average of 5 amps.
  6. #51
    zaylor's Avatar
    Nov 2012
    United States
    This is with every setting maxed out. And it is not connected to the head unit; it is connected to my laptop with the headphone jack > rca cables.
  7. #52
    >>SQL<<'s Avatar
    May 2011
    USA
    1,461
    1 Post(s)
    most likely the amp in the box is bad.
    However it really just isn't worth trying to make work.
    You would be 10x happier with this setup
    Kicker 10" Loaded Truck Sub Box 4 Ohm (10C10-4) - 110TRUCK_10C10-4-N
    and a cheap $50 amp. I have sold 2 amps in the last year or so that would have worked good for you both for less than $50 each.
    Buy that kicker box from above and post a WTB in the classifieds here on this site for a cheap amp and you will be much happier.
    You got a dead horse there and it wasn't even a good horse when it was alive.
    It ***** that you wasted your money on that setup but take it as a lesson learned.
+ Reply to Thread
  1. Amp Tuned incorrectly??? JL sub BARELY hits...
    By pssst in forum General Discussion
    Last Post: 01-25-2009, 07:36 PM
  2. Subs Barely Moving... Searched Everywhere....
    By chronicblazen in forum Wiring, Electrical and Installation Help
    Last Post: 05-01-2008, 02:05 PM
  3. sub barely moving
    By forumjk14 in forum Wiring, Electrical and Installation Help
    Last Post: 03-20-2008, 09:18 PM
  4. CD Deck Barely Audible
    By andreifs in forum Wiring, Electrical and Installation Help
    Last Post: 03-17-2006, 04:00 PM
  5. Replies: 14
    Last Post: 12-25-2005, 11:32 AM
