Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Reload Thread: Amplifier ground
  1. #16
    Timmy13091's Avatar
    Timmy13091 is offline Team DC
    Apr 2012
    Chicago
    2,989
    1 Post(s)
    1280 Post(s)
    Re: Amplifier ground
    Quote Originally Posted by bangintahoe View Post
    If in your trunk, I'd drill hole by spare tire well, and make gFround on car frame. If under hood, engine chassis
    the ground don't look to bad just the way its screwed down is a joke pull it off look for a bolt no need to drill holes and if your gunna keep same ground put a better bolt it and clean the rest of the paint off you'll be all good
  2. #17
    bangintahoe's Avatar
    bangintahoe is offline Junior Member
    Nov 2012
    Katy, Tx
    2 Post(s)
    Also look for a strut bolt. I see a bunch of guys using that as a ground. And like Timmy said, make sure it's sanded down GOOD, it will be very shiny when ready
  1. **GROUNDING the amplifiers! More POWER?**
    By swollen_cu in forum Wiring, Electrical and Installation Help
    Last Post: 10-17-2011, 09:53 PM
  2. Amplifier Grounding
    By LopezBros13 in forum Wiring, Electrical and Installation Help
    Last Post: 10-04-2010, 01:20 PM
  3. Burnt up my ground terminal on amplifier!
    By SourDeez in forum Amplifiers
    Last Post: 03-29-2010, 06:10 PM
  4. Where to ground amplifier in 2002 altima
    By dakayus in forum Wiring, Electrical and Installation Help
    Last Post: 07-12-2008, 02:25 PM
  5. grounding amplifier RCA's
    By budahbuddy803 in forum Amplifiers
    Last Post: 12-29-2007, 05:58 AM
Tags for this Thread
