+ Reply to Thread
Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 61
Reload Thread: 4500 watts
  1. #16
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is online now CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    2,917
    31 Post(s)
    Re: 4500 watts
    Quote Originally Posted by Boomsday View Post
    NO such thing as to much electrical
    no but def a waste of time and money
  2. #17
    Aug 2012
    2,917
    31 Post(s)
    Re: 4500 watts
    3 deka g31 if u got the room and 2 xs3100 if u dont
  3. #18
    garretttt4's Avatar
    garretttt4 is offline CarAudio.com Veteran
    Aug 2012
    Watertown sd
    2,032
    10 Post(s)
    Re: 4500 watts
    Quote Originally Posted by NASTY08IMPALA View Post
    Best place to get the deka g31? Putting them in the spare tire well so should have enough room...
    Current setup
    OZ audio power 12.1s x2
    DD M80 (lmk if you have a matching amp fs)
    Alpine cde 9852
    4.2 cubes new tuned to 36hz:
    Bought from: Jayzbent, mylows10, logan527, Timmy13091
    Traded with: mylows10(x2)
    Sold to: 03silverado03, foomanchu, heel4lyfe, Timmy13091, wErd
  4. #19
    Aug 2012
    2,917
    31 Post(s)
    Re: 4500 watts
    i get deka blems for 80 bucks ..i think @badazzinky ; has 9 left ..idk if he wants to mess with shipping they weigh abt 80lbs
  5. #20
    garretttt4's Avatar
    Aug 2012
    Watertown sd
    2,032
    10 Post(s)
    Re: 4500 watts
    I'm getting batts very last..... Want to get those right b4 I put my stuff in. How many feet of wire do I need? Can I run 2 pos from front and ground batts in the back to the frame? Then ground amps on other side of the frame?
    Current setup
    Alpine cde 9852
  6. #21
    Boomsday's Avatar
    Boomsday is offline CarAudio.com Veteran
    Apr 2010
    My House
    2,577
    55 Post(s)
    Re: 4500 watts
    never...I have yet to see someone with to much electrical, no waste of time or money
  7. #22
    Aug 2012
    2,917
    31 Post(s)
    Re: 4500 watts
    well i have idk what to tell ya
  8. #23
    Aug 2012
    2,917
    31 Post(s)
    Re: 4500 watts
    yea u can but its better to run 1 pos and 1 neg run from front to back to complete the loop..but yea of u have to u can do 2 runs and gota have great grounds in the back .....id say u will need 60-70 feet if u need wire to do big 3 and wire batteries amd go to amp..depends on if u got dual tn on the amp
  9. #24
    Aug 2012
    2,917
    31 Post(s)
    Re: 4500 watts
    i like audio technix wire its all i run great stuff ...very oversized... @cthedinger ; can hook u up..cheaper than knu too
  10. #25
    garretttt4's Avatar
    Aug 2012
    Watertown sd
    2,032
    10 Post(s)
    Re: 4500 watts
    Wait so I'd be able to get by with 1 pos and 1 neg run? Front to back? Should I just replace my starter batt with a deka and have two in the back ?
    Current setup
    Alpine cde 9852
  11. #26
    garretttt4's Avatar
    Aug 2012
    Watertown sd
    2,032
    10 Post(s)
    Re: 4500 watts
    Iv been looking at this stuff a little too . I'll have to hit him up later on!
    Current setup
    Alpine cde 9852
  12. #27
    Boomsday's Avatar
    Apr 2010
    My House
    2,577
    55 Post(s)
    Re: 4500 watts
    Quote Originally Posted by garretttt4 View Post
    Dont listen to this guy, he will have ur car on fire in no time
  13. #28
    Aug 2012
    2,917
    31 Post(s)
    Re: 4500 watts
    yes replace the starting battery and add 2-3 in trunk ..yes i think 1 run of pos and 1 run of neg is enough
  14. #29
    Aug 2012
    2,917
    31 Post(s)
    Re: 4500 watts
    car on fire??ur high maybe if you install it ....i got a g34 deka under the hood and a g31 in trunk with one run of pos to back ..big 3 and stock alt and have no problems at all.....esp no fires
  15. #30
    Aug 2012
    2,917
    31 Post(s)
    Re: 4500 watts
    guy went from 1 run to 4 runs gained .1v...worth it?? ur call but id like to know what @Boomsday ; thinks im telling.u will have ur car on fire
+ Reply to Thread
  1. 4500 Watt Max Amp w/ 2400 Watt RMS Sub??
    By king_kong110 in forum Subwoofers
    Last Post: 01-28-2010, 05:11 PM
  2. Highs for 4500 watts worth of subs??
    By treylittlefield in forum Speakers
    Last Post: 12-28-2009, 06:08 PM
  3. 800 watt amp for sale
    By <SuckMikeHawk> in forum General Discussion
    Last Post: 01-07-2002, 11:29 PM
