Results 1 to 9 of 9
Reload Thread: wiring 2 amps
    yamaha326's Avatar
    yamaha326 is offline livin loud
    Dec 2003
    Texas
    938
    wiring 2 amps
    im a newbee at this but i was wondering how you can power two amps together
    1994 GMC SIERRA ext cab on 22's
    headunit.........p.o.s.sony
    speakers.......4 kenwood 4x6
    amp............1 hifonics bx2006i
    subs........... 2 12"kicker L7
    box...........ported 2.25 cu ft each tuned to 35hz
    wiring....scoshe
    too lazy..but need big 3 done!!!
    15" kicker cvr
    ported 3.5 cu ft sealed----------------------------------------------------------------
    aim--ymracing43
    [email protected]
    pavengmike6's Avatar
    pavengmike6 is offline Senior VIP Member
    Feb 2004
    florida
    497
    Re: wiring 2 amps
    You can do it a few ways. You can run 2 different power wires, or you can go buy a 0 or 4 ga power wire run it to a distro block (you can get these at the audio store) and bridge it off there. The remote is simple, run it from the back of the HU to one amp, and tie into that wire with another piece and run it to the other amp.
    Ground can be done a few ways. Use 2 different ground points, get another distro box and make one common ground.
    Feb 2004
    florida
    497
    Re: wiring 2 amps
    Sorry. Make sure if you run one power wire it is big enough to handle the current draw of both amps.
    yamaha326's Avatar
    Dec 2003
    Texas
    938
    Re: wiring 2 amps
    ok thatnks for the help
    focused313's Avatar
    focused313 is offline Learning With Every Post
    Mar 2004
    Michigan
    267
    12 Post(s)
    Re: wiring 2 amps
    Yea, I'd say use one grounding point though. You don't want any grounding loops. Get the highest guage you can afford for your power wire, should you decide to use just 1 to run into a distrobution block.
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    42
    8,933
    Re: wiring 2 amps
    Unless you are running two pretty big amps, Walmart has a 2 amp install kit made by Scosche that has pretty much everything that you need from 4 ga to run from under the hood (with an inline fuse holder) to a distro block to 8 ga to run to the amps to terminals, RCA's and remote wire. Best part is it's really inexpensive for what you get.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Central Ohio
    31
    3,509
    Re: wiring 2 amps
    Yea the Walmart kit works good for like $25. If you not running 2 high output amps that wamlmart kits works well. I have used it myself to do installs. But you might want to use a bigger ground than the 8 ga they give you. I always buy a piece of 4 ga for the ground.
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
    FinalWolf's Avatar
    FinalWolf is offline Stop reading my subtitle!
    Feb 2004
    Over Here
    30
    871
    Re: wiring 2 amps
    Could I use 4awg for a BX1000D and ZX6000? (running 1 4awg into a dist. block)
  9. #9
    helotaxi's Avatar
    Dec 2003
    42
    8,933
    Re: wiring 2 amps
    With tha kind of power, I would definitely be looking at 2 ga or 1/0 for the primary power wire and then 4 ga from the distro to each amp.
  1. wiring 2 amps
    By alti98 in forum Wiring, Electrical and Installation Help
    Last Post: 03-12-2004, 10:04 AM
  2. wiring to amps to one sub
    By bobo244 in forum Wiring, Electrical and Installation Help
    Last Post: 01-16-2004, 09:46 PM
  3. wiring two 1 ohm amps
    Last Post: 01-15-2004, 12:16 AM
  4. wiring 2 amps????
    By lpman18 in forum Wiring, Electrical and Installation Help
    Last Post: 10-12-2003, 01:31 PM
  5. i need help wiring 2 amps!!
    By MTX BUMPA in forum Wiring, Electrical and Installation Help
    Last Post: 09-14-2003, 11:35 PM
