Results 1 to 15 of 15
Reload Thread: 2 D4 subs need 4 ohm final
    mat3833's Avatar
    mat3833 is offline CarAudio.com Elite
    Mar 2008
    florida
    1,070
    232 Post(s)
    ok, so for some reason my brain is telling me that i should wire each sub to 2 ohm and then wire them together into a 4 ohm load for optimal performance. but i have them each wired to 8 ohm and wired together to 4 right now and **** seems fine.
    would there be any benefit to running each sub at 2 ohm instead of 8 ohm?
    Matt
    butterMilk's Avatar
    butterMilk is offline CarAudio.com Elite
    Jun 2012
    BC
    501
    182 Post(s)
    Re: 2 D4 subs need 4 ohm final
    You should wire to 1 or 4 ohm
    Rockford Fosgate® - Woofer WiringWizard
    And by wiring to a lower ohm, the subs will draw more power from the amp. If your amp can handle it.
    mat3833's Avatar
    Mar 2008
    florida
    1,070
    232 Post(s)
    i should wire to 4 ohm since i have a 4 ohm stable amp. i am asking if wiring the subs to 8 ohm has any benefits to wireing them to 2 ohm or vice versa...
    honestly i dont think it makes a difference but for some reason my brain is saying wire them lower and each woofer will "see" more power. but that cant be right.
    Matt
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,902
    3 Post(s)
    1624 Post(s)
    No it doesn't make a difference, either way you're getting 4 ohms
    BrownVanMan's Avatar
    BrownVanMan is offline CarAudio.com Veteran
    May 2009
    Minneapolis MN
    2,018
    1 Post(s)
    331 Post(s)
    the only difference is if maybe you end up with a 3.9 vs say a 4.1 finaly load. really though it is pretty much the exact same either way. just easier to wire down to 1 ohm later if you wanted going the other direction.
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,135
    25 Post(s)
    2109 Post(s)
    Subwoofer Wiring Diagrams, Two 4 ohm Dual Voice Coil (DVC) Speakers run 2 or 1ohm load,4 ohms is just fine as well.A good amp is worth the the trouble
    mat3833's Avatar
    Mar 2008
    florida
    1,070
    232 Post(s)
    i kno, im in the market for a new amp. but i figured id see how much power i can get out of this Klipsch Promedia 2.1 amp i have laying around. lol, i still cant get klpisch to tell me if it is 2 ohm stable or what.
    Matt
    shizzzon's Avatar
    shizzzon is online now I am who you think I am
    Apr 2008
    KY
    1,217
    16 Post(s)
    263 Post(s)
    Quote Originally Posted by BrownVanMan View Post
    Using the same 2 subs and same wire for both wiring techniques, that would be 100% impossible unless you intentionally made the connections loose on one of the two methods.
    Ohms law Ohms law Ohms law....
    There is no difference.
    Same thing as running 2 amps independent vs them strapped.
    Independent will usually put out slightly more power but it's so little it's not even worth mentioning.
  9. #9
    Chriszle's Avatar
    Chriszle is offline CarAudio.com Elite
    Jan 2011
    SD
    1,718
    373 Post(s)
    I always wire subs in parallel rather than series. Wiring subs in series can cause distortion.
  10. #10
    shizzzon's Avatar
    Apr 2008
    KY
    1,217
    16 Post(s)
    263 Post(s)
    Quote Originally Posted by Chriszle View Post
    Please do not spread false information
  11. #11
    DoesDad's Avatar
    DoesDad is offline CarAudio.com Veteran
    Dec 2011
    Tulsa, OK
    2,342
    675 Post(s)
    Quote Originally Posted by shizzzon View Post
    I think he was trolling... At least I hope he was trolling.
  12. #12
    mat3833's Avatar
    Mar 2008
    florida
    1,070
    232 Post(s)
    some pple its REALLY hard to tell sometimes. lol
    Matt
  13. #13
    May 2009
    Minneapolis MN
    2,018
    1 Post(s)
    331 Post(s)
    but impediences are not perfect ive switched from parallel to series and gone from 4.1 to 3.9 with all connections soldered and spring terminals on the sub. thats why i said its not noticable.
  14. #14
    Chriszle's Avatar
    Jan 2011
    SD
    1,718
    373 Post(s)
    Not trolling. Here's the explanation. Due to slight and unavoidable differences between speakers and the high likelihood of uneven loading between different speakers in a car, there will be slight differences in the mechanical behavior of the two speakers in series. These differences in movement result in the creation of induced voltage (called back EMF) by the speakers across the series connection. This effect causes a problem when two speakers that behave differently are connected in series because the speakers can modulate each other (cause each other to move), resulting in distortion. The problem becomes more serious as more speakers are connected in series.
    The following is a good experiment to show the effect of back EMF: connect four speakers in series and short the positive and negative input leads of the series circuit. Push down on one cone with your hand; you will notice that the three other speakers will move in the opposite direction of the one you are pushing. Now, reconnect the speakers in parallel, short the inputs and push down on one cone. The speakers will not modulate each other because each one is shorted directly.
    Back EMF modulation is not a concern when the voice coils of a dual voice coil speaker are wired in series to each other because the coils are physically coupled on one moving mass. Therefore, they cannot possibly modulate each other because they cannot move independently.
  15. #15
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    For safety reasons, it's always better to wire each sub in series then parallel the two subs. If one of the jumper wires between coils should come loose the sub stops playing and the other sub still gets the same applied voltage as before. If the subs are in series and a jumper wire comes loose the voltages across the subs will change from 50/50 to 66/33 which could over power one of them.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  1. d4 sub @ 3 ohms? -_-
    By caraudio93 in forum General Discussion
    Last Post: 08-01-2011, 04:49 AM
  2. Can I wire 8 d4 subs to a 2 ohm final load?
    By mgcauctions09 in forum Subwoofers
    Last Post: 09-16-2009, 11:46 PM
  3. Final subs need your vote
    By KnOkIn It 420 in forum Subwoofers
    Last Post: 12-13-2005, 02:43 PM
  4. sub config for 1 ohm final load
    By Jayhawkk in forum Wiring, Electrical and Installation Help
    Last Post: 10-26-2004, 10:44 AM
  5. Ohms with amps and subs...need some help
    By Chris02NeonSXT in forum Amplifiers
    Last Post: 08-13-2002, 07:10 PM
